4:3 Big Sceens that offer native 16:9 mode?
Discussion in 'Displays' started by John S, Jan 28, 2004.
  1. John S
    John S Producer
    Nov 4, 2003
    5,460
    I found out something last night about my new Philips, that sort of burns my ass.
    It clearly states everywhere in both pre-sales litterature and the manual. That a native widescreen mode is available for the HD 480p/1080i component video input.
    But in reality, that mode is only available for 1080i source on that input.
    480p locks into full 4:3 mode, no way to switch it.
    My question is this:
    Is there a way to defeat this in the service menu for my 480p sources? I don't want to be able to switch it, I just want to be able to play 1:78 movies and wider with the player set for a 16:9 AR tv, just as I do with my HI-Def 1080i sources. I would relagate my other player for Pan & scan dvd duty at that point.
    I suppose the other answer for me, would be to find a DVD player that scales to 1080i out the Component Video out.
    Thanks in advance...
  2. nick_rh
    nick_rh Stunt Coordinator
    Jan 1, 2003
    86
    Have you tried switching your DVD player to output 16x9? Should be in the setup menu. If you activate that, maybe the TV will auto-detect the anamorphic picture and switch into 16x9 mode.
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    As Nick says, enable your player's 16:9-output mode. In cases involving 4:3 displays without a 16:9 "squeeze" mode, the correct player output should be 4:3 letterbox.
    But if your RPTV has a raster-collapse mode, then your player should be set to 16:9.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    I do understand, how to set it....
    On the HD Component 480p/1080i input it allows for Native Widescreen, I have to switch the TV manually to do this.
    Works great for HD sources, but on 480p sources it actually "Locks Full" and I cannot switch it.
    I was thinking from the service menu, I could sort of force this on 480p sources on that input somehow.
    It is probably not an option though. A scale'n DVD player outputting 1080i would work I have no doubt.
    On a positive note, the new DCDi player does seem a little better on the jaggies for sure. But I am getting a better anamorphic squeeze when I use the 480i component video inputs allowing the TV to perform the progressive scan.
    Just seemed like there may have been a way to sort of trick it in the service menu. Duplicating the geometry produced from the 16:9 squeeze mode (Native Widescreen) that is available on 1080i sources on that input is all.
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    I am getting close to having 200 hours on the set, I am planning on having it professionally calibrated soon, I will re-visit this with the calibrationist...
    Right now here is what I am faced with....
    480i component video allowing the tv to do the progressive scan: More jaggies, but what looks like good anamorphic squeeze on 1:78 content and wider.
    -vs-
    480p component video with nearly no jaggies, yet what appears to be no anamorphic squeeze at all on 1:78 content and wider.
    Both still look quite remarkable overall though....
    Is there a list of known DVD players the will scale to 1080i out the component video ports, I would be hope'n for DCDi in such a player as well???
    Actually what I would really like is the above, and SACD and DVD-A also.....
