3rd Component Input
Discussion in 'AV Receivers' started by Todd Henry, Feb 3, 2005.
  1. Todd Henry
    Todd Henry Second Unit
    Feb 4, 2002
    324
    I am trying to decide the value of getting a receiver with 3 component inputs. I do have 3 components that use component video (HDTV, DVD, XBox). However, I have enough inputs on my TV if I didn't want to have the receiver do the video switching.
    However, if I run all 3 components through the receiver into the 1 input on the TV then I can't do Picture-in-Picture with those inputs, right? If the receiver does Component conversion and I hook up another component via S-Video (old DirecTivo) to the receiver the component out to the TV would control the picture and I would not be able to use PIP either for that input too.
    Also, I won't be able to listen to the TV sound when playing the X-Box which I do sometimes without a second set of speakers.
    What other benefits of running all 3 components through the receiver am I missing?
    Todd
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Very few displays allow picture in picture for HD sources by the way.
  3. Todd Henry
    Feb 4, 2002
    324
    My Sony lets me show the HD Receiver plus the SD Directivo with PIP.
    Todd
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    My Sony lets me PIP anything hooked up too.
    Since you have enough inptus, I don't see any benefit at all, of running everything through the receiver. The ONLY difference is that video and audio are both selected at the same time, and that isn't a gain if you lose PIP. IMO, I wouldn't bother using a higher level connection for game systems unless it was also being used for DVDs anyway. S-vid and component have the same basic resolution, though color will be better via component.
