3802 Troubleshooting
Discussion in 'Archived Threads 2001-2004' started by Mike Strassburg, Jul 21, 2002.
  1. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Returned home from a business trip today to discover that the ON/STANDBY button is flashing. According to the manual it's either over-heating, which can't be the case since it hadn't been played recently, or one of the speaker connections is shorted.
    I disconnected ALL of the speakers from the unit and still get a flashing light. I tried resetting the processer and still no luck. Could the unit have been over-heated/played too loud while I was gone, and not be able to recover? I can't believe my wife/son would play it that loud with 9 Klipsch towers hooked up.
    Any other ideas??? TIA...Mike
  2. James Stierman
    James Stierman Stunt Coordinator
    Jul 21, 2002
    88
    Does the reciver turn on and then click right off again after, or does it not power up at all? I sell denon recivers and am having a similar problem with the 4802. It will turn on for a few seconds, then immediatly shut itself off, with the standy button blinking like it's overheating. I know it is not though as we have yet to get it working properly.
    James
  3. peter a
    peter a Stunt Coordinator
    Jun 18, 2002
    96
    i'm having the same problem on my 3802- my brother was trying to watch tv today, and he said it would turn on for about 5 seconds, and then go to standby mode.... i wasn't there- so i'll look into it tomorrow. i know everything is corrected properly- so, maybe when i get there, i'll disconnect all of the connections and see if it still does it... if so, chris at 6ave will be getting a call... has anyone else had this problem on their new 3802? thanks-
    p
  4. Mike Strassburg
    Nov 4, 2001
    421
    Mine will try to power on for a few seconds, but no display shows up, then it will click and go into StandBy with the blinking light.
    Of course I bought it on-line from an unauthorized dealer, before I knew all about that mess, so I'm going to be stuck paying to get this POS fixed.
  5. Matt AFA
    Matt AFA Extra
    Jul 9, 2002
    17
    How do you reset a Denon receiver?
    Thanks.
