3802/3803 question
Discussion in 'Archived Threads 2001-2004' started by Matt Weldy, Oct 28, 2002.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    Can you adjust each channel by itself or is there just an adjustment for rear. What I want is I have a left surround a little further away than the right. So I need to bump up the volume in that speaker alone. I assume that if the 3802 does the 03 will as well. I was thinking of buying the 4802. But that is twice as much. And I will be working towards the seperates. I figure an extra 1200 is a little much for a remote that no one likes and for a thx logo. That the 03 probably comes pretty close to those standards anyway. Somebody plese correct me if I am wrong. I will be upgrading from a sony 835 reciever so I am sure anything will sound night and day better.
  2. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    For the price of 4802 you can get the 3803 and a decent used 5 channel 125w/ch amp that will blow the 4802 in dust, IMHO. The 3803, from its spec sheet, seems like a sweet prepro that can compete with the 4802 in terms of sheer processing power and when hooked to an external 5 channel amp will give even the 5803 the run for its money, IMHO.
  3. Bryan Acevedo
    Bryan Acevedo Second Unit
    Aug 7, 2001
    290
    And to answer your other question - the 3802 (and presumably the 3803) does allow separate adjustments for each speaker independently, including the surround speakers.
    Bryan
