34" widescreen with VGA inputs under $2000... my options?
Discussion in 'Archived Threads 2001-2004' started by Joseph Goodman, Jul 23, 2002.
  1. Joseph Goodman
    Joseph Goodman Stunt Coordinator
    Feb 4, 2001
    132
    What the topic say, pretty much.
  2. James Stierman
    James Stierman Stunt Coordinator
    Jul 21, 2002
    88
    None?
    Loewe 30 inch planius sells for 2799.99 Thats the cheapest i can think of.
  3. Michael Lomker
    Michael Lomker Stunt Coordinator
    May 17, 2002
    164
    You won't find VGA at that price. Indeed, I haven't seen a 34" set at that price at all.
    If you had more like $3k to spend then you could look at the Princeton Graphics AR3.4FTW when it comes out. Princeton's AR3.0HD is considered one of the best sets for the money and they have VGA inputs.
  4. PaulCh
    PaulCh Auditioning
    Jul 31, 2002
    Check out the 34" Sampo SME-34WHD5. I've never seen the set myself but there are several good reviews on the net (e.g., http://www.sampoamericas.com/news/PerfectVision.pdf). Once properly set up it is supposed to have a great picture and it does computer formats up to XGA. On the downside, it doesn't have many bells and whistles and the 480i performance is not very good because of a relatively cheap filter that is used only for 480i. I suspect you're not buying an HDTV for 480i performance anyway. There are several sellers on the web that list this unit for under $2000.
    Paul
