34" the Largest Widescreen CRT ?
Discussion in 'Displays' started by LewB, Nov 24, 2003.
  1. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    Here's my tale of woe:
    I want to replace my 32" 4:3 set and upgrade to HD. The set currently resides in a large (and expensive) cabinet. If I gut the cabinet I think I can just barely fit the 34" Sony CRT in there (either 510 or XBR). I'm still not sold on projector sets due to the fact that their viewing angle is sort of limited, and plasmas are still a bit pricey. Anyway, I was wondering why 34" seems to be the limit as far as widescreen CRTs go. Is it:
    • Cost
    • Weight
    • Technology Limit
    • All of the Above
    P.S.
    Lesson learned: Don't buy cabinets that surround your gear, makes aspect ratio changes a complete PITA !! [​IMG]
  2. Rocky F
    Rocky F Second Unit
    Jun 13, 2002
    371
    There is a 38" tube that RCA used to use and Loewe (sp) currently uses for there Aconda model.
  3. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    Yeah, I just saw that Loewe on the web, they have a magazine review on their web page that was a absolute rave. The reviewer said that the picture was about as perfect as you could get out of the box without a profesional calibration. I see it ONLY costs $4,000 ! Weighs 220 pounds too ! Now you're getting into the price range of plasmas !
  4. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    All of the above.
  5. Mike Frezon
    Mike Frezon Moderator
    Oct 9, 2001
    41,385
    7,241
    9,110
    Rensselaer, NY
  6. Richard_B
    Richard_B Stunt Coordinator
    Oct 14, 2003
    137
    LewB,
    I am in the same situation as you with buying a cabinet that surrounds the TV. I have a 32" tv and am also looking for a 34". Both Sony's are to wide, JVC, Zenieth & RCA are also too wide. What I can fit is the Panasonic, Philips, and Toshiba at least from what I have found so far. Have you looked atany of these sets? If so what's your opinion on them? I am asking because it seems to be hard to find a lot of info on 34"sets.
  7. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    I saw a 34" Philips at BB the other day that couldn't come close to the Sony. Of course my judgement could have been skewed by the way the TV was set up, YMMV.
    I definitely like the picture on the CRTs better than about anything else out there.
    Another question:
    If I was happy with the size of a 4:3 32" set, will a 34" 16:9 seem as large ? My viewing distance is around 6-8 feet.
    Man, these are some tough decisions. Any one wanna buy a nice piece of Ethan Allan cabinetry, cheap ? [​IMG] [​IMG]
  8. Mike Frezon
    Oct 9, 2001
    41,385
    7,241
    9,110
    Rensselaer, NY
    I LOVE Ethan Allen furniture! But....too late! My new cabinet is already in place and filled up! [​IMG]
    Here's a way to compute the viewing size of two different sets:
    Click here.
    Good luck!
  9. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    Mike:
    That calculator says that the 32" 4:3 and 34" 16:9 sets are about the same in total square viewing area. The picture size varies based on the type of image being displayed. You lose area (picture size) when the 4:3 shows widescreen material and when the 16:9 shows non-widescreen material.
    Amazingly enough, the guy at BB told me that the viewing area of the 34" widescreen and the 32" 4:3 were about the same. The guy was actually right ! [​IMG]
  10. Mike Frezon
    Oct 9, 2001
    41,385
    7,241
    9,110
    Rensselaer, NY
  11. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
  12. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
  13. Lew Crippen
    May 19, 2002
    12,060
    One more point Lew, is that the new, flat screen CRTs not only weigh a lot, the bulk of the weight is on the front of the set. This means that you really can’t have the front of the set overlap the cabinet (put another way, the cabinet has to not only be wide enough, it has to be deep enough). This also means that the cabinet has to have strong enough bracing on the front to support the front of the CRT.
  14. Dwight Amato
    Dwight Amato Stunt Coordinator
    Nov 29, 1998
    193
    It is true, all of these tube sets are increadibly heavy. A good thing about the Sony 34" XBR, is that Sony has a deal right now that it ships with the matching stand for free. This is good from any Sony retailer. The stand is made specifically for the set and even has a strap in back to lock the set into place. I got my stand today and the set comes tomorrow, yehaw!
