34 lbs center channel on top of RPTV
Discussion in 'Speakers & Subwoofers' started by ArnaudP, Sep 16, 2003.
  1. ArnaudP
    ArnaudP Stunt Coordinator
    Jul 27, 2001
    103
    I would like to buy a new center channel (Paradigm Studio cc470) but it weights 34Lbs! I am worried that it might be too heavy to sit on top of my 48" Mits RPTV. What do you guys think? Thanks.
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    You should be just fine. Plenty of people over at Klipsch use the 38lb monster(KLF-C7) I'm using with no problem on their RPTV's.
  3. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    No problem at all. I have a 45lb center on top of my 55" Mits RPTV and it has had no problems at all. If you're really worried you could place a sheet of glass or shelf of some sort that fits over the entire top of the TV and the speaker on top of that. The shelf will help distribute the load better.
  4. Scott Kriefall
    Scott Kriefall Second Unit
    Mar 9, 1999
    332
    110
    SLC, Utah
    Scott
    I had 45+ lbs Paradigm Active-CC center sitting on top of my Mitsubishi 46" RPTV for a few years. No problems whatsoever. Mitsu's seem to have a stronger top than Toshiba's and other RPTVs.
  5. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    110
    Check out this link at another forum and see what you think. The 55" Mits I had *did* bow with my B&W LCR6 on top. 3/8" glass took care of that problem. When I exchanged the 55" for a 65" Mits later on I purchased a new piece of glass, but the added width was too much for the glass to handle, and *it* bowed. I ended up using the exact same wall mount bracket pictured half way down in the link I provided, works great!
    Good luck!
    Pete
