ThomasL
- Mar 13, 2001
On any of the above mentioned models, has anyone calibrated their set with Avia (or VE)? If so, can you post your findings for the following?
(1) Red push in the color decoder? If so, how much?
(2) How well does it hold black level across the different Avia patterns - black with black, gray with black, white with black. In a perfect world, your brightness setting shouldn't change no matter which pattern you are looking at.
(3) What does the grayscale look like in the 'warm' color temperature setting? Is it still bluish? or reddish?
or greenish?
(4) What is the geometry like? Any problems in the corners or on one side?
thanks,
--tom
or greenish?
thanks,
--tom
