chris hunigan
Grip
- Jan 4, 1999
I have two subs that I am in the process of building. 1st sub: If you don't know I have been talking about my sub, which is called "SubTeRRainiaN", which will consists of (4) 12" drivers within a 30"d x 48"h sonotube. I will be using a 12" sonotube port cut down to 27", which gives me an F3 around 22Hz.
2nd sub: This is a dual 12" sealed sub. The only thing I need to do is apply a nice finish, sand it down somewhat, and place the drivers in. This stands roughly 36"h x 14"w x 16"d. Each sub will have its own 2 cu ft enclosure. I will stuff almost 50%-75%.
So I will go more into detail once I complete the subs later on. Hopefully, I can provide pics soon as well.
Now enough with the babble.............!
Since I will using two different subs within my system, should I go with a 31-band EQ or BFD to smooth out the bass response within my room? Which would be a better choice for my situtation?
I know the ART351 is a highly considered EQ, but I posted an EQ awhile back called the Nady GEQ130, but wasn't highly recommend since it did not have variable/adjustable high and low pass filters. Here is the link to the Nady GEQ130:
http://www.musiciansfriend.com/ex/sh...903?pid=183702
cree
cree
