300-500 disk progressive scan player?
Discussion in 'Archived Threads 2001-2004' started by Josh Duve, Feb 9, 2003.
  1. Josh Duve
    Josh Duve Extra
    Jun 4, 2000
    15
    Does anyone make a 300-500 disk progressive scan on-screen DVD player?
  2. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Josh, check out the Sony DVP-CX875P. It holds 300 DVDs and sells for around $400-500. You should be able to get it at a good discount through Oade Bros. (1-229-228-0093 or 1-229-228-4480), OneCall (1-800-340-4770), or J&R Music World (1-800-221-8180), all of which are authorized dealers. For more on the 'CX875P, go to www.crutchfield.com .
    Also look at the Kenwood Sovereign DV-5050M and '5900M. Both hold 403 discs. They have gotten good reviews on the video side (no chroma bug), and the '5900M plays DVD-Audio discs. Go to crutchfield.com for more on these players. Note that Kenwood does not authorize mail-orders sales of its Sovereign products.
    On a final note, no one has made a 500-disc changer of any kind (CD or DVD). The largest capacity made thus far is 403 discs (the aforementioned Kenwood models). Sony makes a couple 400-disc CD megachangers.
  3. Josh Duve
    Josh Duve Extra
    Jun 4, 2000
    15
    Thanks Keith
  4. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Josh, no problem. Best of luck in your search.
