Matt_Smi
- Apr 11, 2004
- blank
Ok here is the deal, I have $840 to spend at Circuit City because my older Sony WEGA developed a flaw and since I had a service plan they refunded the cost. I was planning on buying the Sony 27” KV-27HS420 for $750 when it comes out. But now I am thinking that spending the extra $160 to get ether the 30” (KV-30HS420) or the 32” (KV-32HS420) would be a wise investment as my room is fairly large and I think that a 27” is a bit too small for it. But there are two problems, one which should I buy? I mainly watch a lot of DVD’s and play a lot of PS2 games, I may be getting a HD box soon after I get this set but I am not sure yet, and as for regular analog TV, I watch a fair amount but I am not a huge TV watcher in general and mostly just have it on for background. I think I would be better off with the 30”, but one thing that concerns me is that not all video games have a 16:9 mode, so I would need to play them with bars on the side, which could be annoying, but most new games coming out should have a 16:9 option. Another reason the 30” is more appealing to me is because it is more future proof than a 32”.
The second problem is my current TV stand will be a bit too small for the 30” and I do not want to buy a new one nor can I fit a new/bigger one on the wall my TV is on. The measurements of my stand are as follows, 31 and a half wide and 19 and a half deep. The 30” TV is 35 inches wide and 22 inches deep, but I think this may be fine as the sides and back of the TV will just hang off the stand a few inches. My stand is rated at 135 pounds and the 30” TV weights 150, but I don’t think that 15 pounds over its weight limit will put the stand in danger of collapsing, so I should be fine there as well, but I am not 100% sure. Even though Sony does not list it on their site yet I know that the 32” weights more, because the 32” 510 weights 176, so I am guessing that the 420 is very similar in weight. That right there pretty much rules out the 32” as my stand will not be able to support it safely. But do you guys think that it will be fine with the 30”? I linked to a few (outdated) pictures of my room, so you can see the TV stand (with my old WEGA) and get an idea of how big the room is. And let me know what you think, 30” or 32” (even though I cannot really get it) or just stick my the plan and get the 27”? Thanks.
Front of Room
http://images.cardomain.com/member_i...98_19_full.jpg
Back of Room
http://images.cardomain.com/member_i...98_17_full.jpg
Front of Room
Back of Room
