#3 vs #4 rebar
Discussion in 'After Hours Lounge (Off Topic)' started by DannyL, Oct 20, 2004.
  1. DannyL
    DannyL Stunt Coordinator
    Dec 18, 2001
    77
    i'm having some concrete decking put in. i asked the contractor to put in #4 rebar but he says that #3 should be fine. he says that it is harder to evenly pour over #4 because of the thickness. we plan on putting some heavy marble and concrete furniture, fountain, etc. i'm worried about cracking. will it make any difference? thanks.
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Well yeah, or there wouldn't be two different numbers. What does the contract call for?
    If it says 4 and he's skimping, oh, oh, take pictures before it's poured!
    Glenn
  3. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    The number on rebar is the size in eighths of an inch. number 3 = 3/8", Number 4 = 4/8 or 1/2". I'm not an engneer so I'm not sure if there will be a real difference in bearing capacity (off the top of my head it seems OK, but knowing the exact use and conditions would help) but I can tell you that the excuse about it being harder to pour over is absolute BS since you are only talking about a difference of 1/8".
  4. Glenn Overholt
    Mar 24, 1999
    4,203
    Yep, that is BS. Maybe, and I really don't know, the #4 is much, much harder to bend. But at any rate, if they use 3 take some pictures before it is poured, and if it cracks later, you'll have some evidence when you sue.
    Glenn
  5. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    I'm wondering if the guy has some #3 rebar left over from another job and wants to use it for that reason.
  6. John Alvarez
    John Alvarez Screenwriter
    Sep 3, 2004
    1,129
    When you say decking do you mean suspended in air or is it a patio on grade?
  7. Adam.Heckman
    Adam.Heckman Second Unit
    Dec 9, 2003
    322
    I'm at work right now. In a structural design firm (across the Charles river from Fenway! GO SOX!).
    Let me know the loading on the deck, slab thickness, and what type of metal decking you're using and I'll let you know.
    Not that I can tell you myself, I'm just a lowly drafter, but I can find out...
  8. DannyL
    Dec 18, 2001
    77
    thanks for all the replies. haven't checked my computer since yesterday. it going to be a back yard patio 6 inch slab. roughly a 20 foot dimater circle. we are thinking about a large 14-16 foot diameter gazebo with a tile roof or a very large fountain- 12 foot diameter. i know the fountain is greater than 1000 lbs.
  9. John Alvarez
    Sep 3, 2004
    1,129
    I don't think you need rebar for that unless this is something that you want. I know here in Fl. all our patios are 4inch pour with no rebar. You'll want to make footers to support the gazebo. Make sure you check code in your area to determine what's required for size and load.
  10. DannyL
    Dec 18, 2001
    77
    i don't have any local codes requiring the rebar, but i just want to lessen the chance of having severe cracking in the concrete.
  11. Glenn Overholt
    Mar 24, 1999
    4,203
    John - think earthquakes.
    Glenn
  12. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I just finished a 9'x9'x4" pad for my hot tub and used #4 rebar which was major overkill. Keep in mind that the fountain's load will be distributed (a woman in high heels probably exerts more psi on the concrete). For the gazebo you may be required (by code) to pour footings... especially in CA.
  13. John Alvarez
    Sep 3, 2004
    1,129
    I'm used to sink holes that swallow everything....[​IMG]
  14. Lee L
    Oct 26, 2000
    868
    I would not worry about the #3 rebar then. I would definitely thicken the slab to about 12" at the locations you might expect a future fountain or gazebo to bear on the slab and make sure rebar is in the bottom 1/3 of the pour in those areas. In central NC, for the rest of the slab, you would be more than fine using 6/6 10/10 wire mesh. (a 6"x6" grid of 10 guage wires). In LA with the seismic requirements, maybe rebar would be preferred but is still seems overkill for an unattached accessory structure on a slab.
    Also, you might be well advised to run some 1 inch conduit for electrical and maybe something larger for future water lines if you really wnat to do that fountain. Even if you just stub them out 12" from the edge of the slab and not use them for a year you will be happy one day if you ever do and it should cost you virtually nothing.
  15. DannyL
    Dec 18, 2001
    77
    thank you all for your help! [​IMG]
  16. Glenn Overholt
    Mar 24, 1999
    4,203
    John, I've seen quite a few news clips of sink holes on TV! See, if the whole thing is going to go, the rebar won't help!
    The quakes get just as picky as tornados or anything else like that, If it ripped down the center of this new project and split it, who knows where 1/2 of it may be sliding off to. If something is on the center where it split, that might slide off too. The house (just a few feet away) can get no damage at all until this slab slides into the bedroom. Ouch!
    I really don't know, though. As long as the local building codes are met, but I do want to know how this whole subject came up with you, Danny.
    Glenn
