3" to 6" shielded full-range drivers under $25 for satellites?
Discussion in 'Home Theater Projects' started by Robin D, Jan 20, 2003.
  1. Robin D
    Robin D Auditioning
    Apr 1, 2002
    10
    If you have any other ideas for drivers, please do tell! But I think if I'm going to go the single-driver route, then I'll either go with either this one, or this one. Wich one would you go with? The things that lead me to these drivers were the frequency response(below 100hz and above 12k), at least 40w RMS, and their low cost. The most human ears can only hear up to like 12k anyway, and most CDs don't contain any frequencies above 15k, so a single driver satellite that went up to 15k wouldn't be too bad a thing, right? If a two-way satellite is a must have, any ideas on cheap x-overs?
  2. Brian Knauss
    Brian Knauss Stunt Coordinator
    Jan 12, 2003
    61
    There's a couple "full range" drivers for about a buck in PE's Pioneer buyout. I believe the 4"ers go from 100-15kHz
  3. Robin D
    Robin D Auditioning
    Apr 1, 2002
    10
    Thanks! What do you think about using 9 of these per channel. I could get 8 ohms out of them, and I could bring the SPL and power handling up to an acceptable level by going with 9. Are there any drawbacks I should be aware of?
  4. Brian Knauss
    Jan 12, 2003
    61
    People seem to have good results with line arrays, so go for it.
    I'm thinking of building a couple MMTMMs for fronts and a center with the 4"ers and cheap Goldwood tweets. Nothing fabulous, but it'll beat what I've got already and will cost hardly anything.
  5. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    Or, if you want Bose Killers with high SAF, use the 3" Tangband drivers that Parts Express sells. They will match up well with the power output of your reciever.
  6. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    What about the AV3 from Adire? I have no personal experience with them and I've only heard them mentioned here once, so does anyone have an opinion on them?
    Andrew
  7. Brian Foley
    Brian Foley Agent
    Jan 25, 2000
    48
    Robin,
    There are some special considerations to be aware of when putting together line arrays. I suggest you read the white paper linked to on this page:
    http://www.madisound.com/cgi-bin/dis...gi?read=231158
    and look for other messages on that same board pertaining to line arrays.
  8. Robin D
    Robin D Auditioning
    Apr 1, 2002
    10
    By the time I get home from work, I'm too tired to think hard enough to understand what all they're talking about! Pretty much all I understood was that I need to make sure my drivers are as close to each other as possible, and that it would be great if I could limit the power of the outer(upper and lower) speakers.
    Should I perhaps put a divider in the middle of the box to avoid "pipe resonance?" Or would it not even matter?
    Also, I need to get the wiring figured out. Is the picture below showing the correct way to hook it up?
    [​IMG]
  9. Brian Knauss
    Jan 12, 2003
    61
    If you're looking to have an 8 ohm impedance, that's the right wiring.
  10. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    The downside to using those drivers by themselves in a line array is that you will start to experience comb filtering at the frequency who's wavelength corresponds with the center to center distance of the drivers. In this case, if you butted them up to each other, they'd be about 4" apart on center. That means that comb filtering would start at around 3.4KHz.
  11. Robin D
    Robin D Auditioning
    Apr 1, 2002
    10
    Well, I guess building a line array isn't the best course of action. I think I will build single-driver satellites to maintain simplicity.
    After looking around, it looks like either this or this. The MCM driver looks like it would be better for music with that 45hz low end. But then that tang band could be put in a box 1/4th the size...
    What do y'all think?
  12. Robin D
    Robin D Auditioning
    Apr 1, 2002
    10
    bump?
  13. Joel X
    Joel X Stunt Coordinator
    Nov 21, 2002
    50
