3 RCA Cables = 1 Component Cable? (1 Viewer)
Scott-C
I apologize if this question is basic and obvious, but I'm honestly not sure of the answer. Can three "standard" RCA cables be used as a component video cable to connect a DVD player to a RPTV? (both have component jacks).
I was thinking I could just manually label them "Y", "Red", and "Blue".
I'm not sure if true component cables have different properties than RCA cables.
Thanks in advance for the help!
Scott
Scott H
Aside from labeling, component cables are three composite cables. So, yes.
My DVD Library
Runaway production? No thanks. Where I've filmed, benefiting local economies: AL, CA, ID, IL, IN, IA, KS, MN, MO, MT, NV, OH, OR, TX, WA, WY.
Elbert Lee
Addition - 3 VIDEO RCA cables rated at 75 ohms are what you should consider when purchasing component video cables.
Elbert
Glenn Overholt
While the yellow video cable is rated at 75 ohms, the white & red audio may not be, but there's no harm in trying it out. You could get really sick if you had them lying around and get three sets of A/V cables and just connect the yellows up.
Glenn
SaladinNagasawa
