Charles_Root
- Jun 9, 2004
- Charles Root
Been looking to pick up a projector for watching DVD movies and stuff off the Tivo.
I actually have hooked up and used a friends Dell 2200MP and in a dark room it was quite enjoyable, although if you moved your head real fast white images would get a "rainbow effect" near them anyway below are 3 projectors one is Polysilicon and two are DLP (one being a Dell 2200MP) based on the features in the product litature why is the Boxlight Premiere almost 10 times the price, when the two DLP (at least to my amatuer eyes) seem to be identical (is there some spec I'm not reading as being wildly different)
The Premiere is also more expensive then the Cinema 20 HD which as I read it is brighter and a sharper image. What am missing here?
Thanks for the help
Below are the specs:
DELL 2200 MP - PRICE $889
•Brightness of 1200 ANSI Lumens (Max)2
•Super high 1700:1 contrast ratio (Full On/Full Off) for vivid images
•Built-in advanced motion adaptive hardware de-interlacing with 3:2 and 2:2 pull down for great video
•Preset and user defined video modes for optimum video, entertainment and graphic settings
•Manual zoom and digital keystone correction
•Great connectivity — supports S-Video, Composite Video (RCA), Component Video and VGA inputs
•Supports full range of television and video standards, including NTSC, PAL, SECAM, and HDTV (480i/P, 576i/P, 720P and 1080i)
•Supports 4:3 (native) and 16:9 aspect ratios
•Eco-mode for extended lamp life and quieter operation
•Power saving option — Projector shuts down after a predetermined time
•Auto synchronization technology automatically adjusts VGA to SXGA+ resolution to native SVGA resolution (800 x 600)
•Monitor loop-through allows for viewing on additional PC monitors
•1-year limited warranty3 with Advanced Exchange Service4 (90 days on bulb)
•Ships with Dell drop-tested hard foam carrying case including wireless remote control and necessary cables
•2000 hours (Estimated 2500 hours in Eco-mode) 200 W P-VIP lamp
BOXLIGHT PREMIERE 50HD PRICE $8500
•Resolution: True 1280x720 Wide XGA with _
compression up to 1280x1024 SXGA
•Brightness: 1000 ANSI lumens
•Lamp: 200w VIP
•Lamp Life: 120-day or 500 hours guarantee
(whichever comes first)
•Display Type: Single 0.8” Mustang HD2 12 degree
LVDS DMD™chip; 16:9 aspect ratio
•Color Wheel: 6 segment, 5x speed
•Contrast Ratio: 1700:1
•Colors: 16.7 million
•Aspect Ratio: 16:9 aspect ratio; 4:3 compatible
•Inputs: Computer: 15 pin, DVI-D/HDCP
Video: 2-RCA Component, RCA _
Composite, S-Video
•Outputs: Control Port: RS-232 serial port,
mini-jack for wired remote, _
12-volt relay trigger
•Decibel Rating: 30dB
•Video: NTSC, PAL, 1080i, 720p,
•Encrypted Digital Video: HDCP
•Projection Lens: Manual F/2.4 - 3.0; zoom ratio 1:1.25; _
f=24-30mm
•Diagonal Image Size: 30-300” / 76 - 762cm
•Throw Distance: 3.4' - 42' (1m -12.8m)
•Keystone: Digital eWARP technology, _
+/- 15 degrees vertical, _
+/- 40 degrees horizontal,
•Adjustments: On-board and remote
•Power Supply: 100-240V; 50/60 Hz
•Power Consumption: 300 Watts
•Compatibility: SXGA, Wide XGA, XGA, _
SVGA, VGA, Mac
Weight: 11 lbs/ 5 kg
BOXLIGHT CINEMA 20HD PRICE $7,999
•Resolution True 1366x768 wide XGA with compression for 1280x1024 SXGA
•Brightness 2200 ANSI lumens
•Lamp 200w UHP
•Lamp Life 120-day guarantee
•Display Type 3-1.2in TFT polysilicon with micro lens array
•Contrast Ratio 900:1
•Colors 16.7 million
•Aspect Ratio 16:9 native, 4:3 compatible
•Inputs Computer: (1) DVI, (1) 15-pin for computer,
(1) BNC x 5 for computer or component
video. Video: (2) Composite, (1) RCA
Component, (1) S-video. Audio: (1) RCA
(L/R), (2) computer
•Outputs Control Port: (1) serial port
•Decibel Rating 35 dB
•Audio (2) built-in 2 watt speakers
•Video NTSC, NTSC 4.43, SECAM, PAL, PAL-M,
PAL-N, 1080i, 1035i, 720p, 575p, 575i, 480p,
480i
•Weight 17.4 lbs/ 7.9 kg
•Dimensions 12.6"/31.9 cm (W) x 6.6"/16.8 cm (H)
x 16.9"/43 cm (D)
•Projection Lens Motorized zoom and focus, 1:1.3 zoom
ratio, F/1.8-2.1 (f=48.4-62.8mm)
•Diagonal Image Size 30-400"/76-1016 cm
•Throw Distance 4.9'-51'/1.5-15.6 m
•Keystone Digital horizontal adjustment of +/- 40
degrees, vertical +/- 10 degrees
•Adjustments On-board and remote
•Power Supply 100-240V; 50/60 Hz
•Power Consumption 300 Watts
•Compatibility SXGA, Wide XGA, XGA, SVGA, VGA,
Mac
Thanks for the help
•Lamp: 200w VIP
Composite, S-Video
f=24-30mm
SVGA, VGA, Mac
•Lamp 200w UHP
(L/R), (2) computer
480i
x 16.9"/43 cm (D)
Mac
