3 Possibilities, one choice, funds limited
Discussion in 'AV Receivers' started by DaveAr, Sep 30, 2003.
  1. DaveAr
    DaveAr Stunt Coordinator
    Apr 8, 2003
    63
    Better bang for the buck?
    Okay, here is what I have come up with. Anyone with prior experience please give all the insight you have. The following systems are in place and are running neck and neck. AXIOM: M60's / QS8's / VP150 ( 1620)
    ROCKETS : RS550 / RSC200 / RS300 (1799) (1718 "B" stk)
    ROCKETS : RS750 / RSC200 / RS550 (1919 "B" stk)
    Any thoughts much sppreciated. Yamaha RX V 2400 arriving any day.
    ( ) = PRICING:b
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Even though most of the yamaha brightness has been worked out in the past few model years, i still wouldn't put axiom and yamaha together unless you're looking for a really bright sound. The rockets and yamaha would probably turn out pretty neutral, so which rocket package you go with should probably be dictated by what sub you have or plan on getting as well as your HT/2ch habits.
    You may also want to look at the Swan Diva line. a 6.1/C3/R3 setup or 5.2/C3/R3 setup would be very similar to the Rocket's and are available in the rosewood finish if you like that, or you could save 33% by going with the black cherry vinyl (i have Divas in this color and prefer it alot to the rosewood). Check them out at www.theaudioinsider.com [​IMG]
