3" or 4" ports on Tempest Adire Alignment?
Discussion in 'Archived Threads 2001-2004' started by Scott Simonian, Jan 30, 2002.
  1. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    I have finally decided on the alignment Im going for on my first DIY sub project. I picked the Adire Alignment. I definetly am using the Tempest.
    Anyway, the design calls for (2) 3 inch, flared ports on the bottom of the cabinet along with the driver. I would like to use (2) 4 inch ports.
    Im assuming Id get a nice reduction in compression, if it would occur in the first place. Can I expect this? Lets say I would get a worthwhile improvement, how long would the ports have to be now?
    They are originally about 11 inches long, tuned to approximatly 15hz.
    Second, would the 4" ports fit on the bottom? The space is pretty tight on the bottom. I guess I could just modify the schematics a little to fit the ports.
    [​IMG]
    Anyone know if they can help?
  2. Going from 2x 3"x11" ports to 2X 4" ports would mean that the center tube would need to increase by ~ 17" (if I did my calculations right
  3. James Slade
    James Slade Second Unit
    Nov 20, 2001
    250
    I asked Dan this exact question because I was concerned about port noise. According to him there is no reason to use larger ports, at least wrt noise anyway.
  4. Scott Simonian
    Jun 20, 2001
    1,281
    Really? I trust the plans and I trust DanW. I just wasnt sure if I would even run into a compression problem with the design. I just dont want it to EVER happen. I hate compression.
  5. Kerry Hackney
    Kerry Hackney Stunt Coordinator
    Oct 18, 2000
    206
    Scott,
    I have just completed the Tempest / Adire Alignment within the last two weeks. I built mine per the plans provided by Adire. I haven't heard any port noise of any kind with mine. I wouldn't worry about changing to 4". And I like the idea of having as much wood on the bottom as possible to keep everything stiff. If you did do it, you are correct in that it will be a very tight fit. The flanges for the ports are pretty big. I think you would end up having to modify them to get it to fit.
    I have checked the ports at different times with various material and you would have to be dumping huge wattage to get anywhere near a problem. At that kind of volume I don't think it would matter anyway. On music software you'll never get close. There just isn't that much content below 30Hz. Build it, you'll be amazed... [​IMG]
  6. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
    With a 3" port the cross-sectional area is Pi * (3/2)^2 = 7.069in^2
    With a 4" port the cross-sectional area is Pi * (4/2)^2 = 12.566in^2
    That's an increase of 77.8% in cross-sectional area. Wouldn't the ports would have to be 77.8% longer? That's 1.778 * 11 = 19.56in
  7. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    No need to increase to 4" and if you did you will run into port length problems for the size of enclosure. Stick with the 2ea 3" and enjoy!
    Kyle Richardson
    Acoustic Visions
  8. Scott Simonian
    Jun 20, 2001
    1,281
    Ok, Ill stick to the 3" ports. I cant wait til I build this monster.
    But if I hear a hint of port noise, Ill blame you guys. [​IMG]
    Im sure I wont run into the problem. Just thought it wouldnt hurt to make em bigger. I dont think it would be difficult to add a few extra inches to the port length. It will be a tall cabinet. Im probably wrong in any case, so dont listen to my babble.
    Now I just need someone to buy my current sub or give my $300. [​IMG]
    EDIT:
  9. Scott Simonian
    Jun 20, 2001
    1,281
    Anyone change their mind?
