3 composite = 1 component?
Discussion in 'Archived Threads 2001-2004' started by Xavior Smith, Jul 5, 2002.
  1. Xavior Smith
    Xavior Smith Extra
    May 29, 2002
    21
    Do I really need to buy a component cable or can I just use 3 composite video cables? The reason I need to know is that I have some high end composite video cables lying around and instead of buying another component cable I would rather just use my composites if possible. Thanks.
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,196
    50
    4,110
    Central FL
    Phil
    That will work fine. I would assume they are all the same type and design?
  3. Xavior Smith
    Xavior Smith Extra
    May 29, 2002
    21
    Yup, they're all the same high performance 75ohm cables. Thanks for the response.
  4. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    110
    VampireWire's Component cables are made up of three composite cables, with a little color-coding heatshrink applied to color code them.
    No difference at all in the actual cable.
    Pete
