3 Channel Amp with Balanced connections
Discussion in 'Archived Threads 2001-2004' started by EricKH, Aug 2, 2001.
  1. EricKH
    EricKH Agent
    Jul 26, 2001
    42
    I am in the process of building an additional HT in my basement. I have the following equipment
    Processor: Meridian 568
    Amp Sides: Adcom GFA-5500
    Amp Rears: Adcom GFA-5500
    DVD: Pioneer Elite DV-37
    TV: Mitsubishi HD 46 inch
    Mains: Monitor Audio Silver 9i
    Center Monitor Audio Silver 12i
    Sides: Monitor Audio Silver 3i
    Rears: Monitor Audio Silver 3i
    AC Power: Richard Gray 1200
    Since the 568 offers balanced connections fot the mains and center, I would like to get a good 3 channel (at least 200 WPC) with balanced connections. Any suggestions that would be at the level of the equipment I have purchased?
    Thanks, Eric
  2. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    The only amp I know of that has balanced connections and is 200 watts a channel is the Anthem mca-3. I think it sells for about 1200-1500.
  3. Adam
    Adam Stunt Coordinator
    Nov 3, 1998
    139
    The Proceed HPA3 is a three channel amp with balanced inputs. Awsome.
    It is rated at 250 WPC. and weighs like 120 lbs. It ain't cheap around $4000, but niether is Meridian.
    There is also, a HPA2, 2-channel version.
    Adam.
  4. Graeme Shiomi
    Graeme Shiomi Stunt Coordinator
    Jan 7, 2001
    70
    There's the 6B-ST from Bryston. Balanced Inputs and 250 WPC (which is conservative, probably closer to 300).
    Graeme
  5. Claude M
    Claude M Stunt Coordinator
    Jan 18, 2001
    239
    The Anthem has the balanced inputs but it's 200W one channel driven. All channels driven it's 175W.
  6. Rick Sorken
    Rick Sorken Auditioning
    Sep 15, 1999
    8
    Eric,
    I have 2-6ch amps from Cinepro. I'm using one for my three front channels which is switchable and turns two channels into 1 high powered single channel. They have balanced and unbalanced inputs. I can't say enough good things about these amps. Have a look here for the models and pricing.
    Thanks Rick
    Rick & Carey's Home Theater
  7. Robert A. Willis Jr.
    Robert A. Willis Jr. Second Unit
    Jul 11, 1999
    306
