3, 8 ohm drivers - how to wire them to get 4-8 ohms?
Discussion in 'Home Theater Projects' started by Kenneth Harden, Feb 17, 2006.
  1. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    If I wanted to use 3, 8 ohm drivers together (in one cabinet), how could I wire them to get between 4-8 ohms?
    The only thing I could think of would be, wire two together to get 4 ohms, and then add the 3rd driver in. That would get me 5.33 ohms (acceptable).
    However, would this cause the sound levels to be different on the drivers?
    Thanks!
    Here:
    http://www.colomar.com/cgi-bin/h_imp...ZxZxZxZxZxZxZx
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,288
    51
    Mississippi
    3 of the same drivers playing the same frequency range? Can't do it and divide the power among the drivers equally.
    3 different drivers each playing a different range of frequencies? That's a 3-way speaker. Design the appropriate crossover and it will work.
    -Robert
  3. Kenneth Harden
    May 13, 2002
    1,365
    No, three full-range drivers all doing the same thing. I cannot wire them in series or parallel (way to high or low of a load)
  4. Mattak
    Mattak Stunt Coordinator
    Dec 15, 2003
    247
    Only real option I see is to make it 4 drivers, then you can do parallel-series for 8 ohms.
  5. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    If it were me, I'd try and use either 1 driver, or 4 or maybe more would sort of make it a line array.
    I don't think 3 full range drivers in a speaker is commonly used...
    1 driver would be by far the easiest. [​IMG]
