3:2 pulldown TV sets
Discussion in 'Archived Threads 2001-2004' started by DennisP, Dec 4, 2001.
  1. DennisP
    DennisP Stunt Coordinator
    May 5, 2000
    109
    Can someone explain whether a HDTV set with a 3:2 pulldown feature requires a progressive scan DVD player (with 3:2) to display those film-like images attributed to progressive scan?
    I talked to a friend that told me the use of a progressive scan DVD player (with 3:2) with a HDTV with the 3:2 pulldown is a waste of money...the TV does the same thing the player does.
    Thanks to those who answer.
  2. Fernando Chen
    Fernando Chen Auditioning
    Jun 30, 1997
    9
    3:2 pulldown on your tv is good for broadcast tv showing sources that originated from film. But for dvds, its still better to have the 3:2 linedoubling occur in the dvd player since it can be done in the digital domain.
    If you let your tv do the 3:2 pulldown for your dvds you add an additional signal degrading step towards producing the progressive image. With a regular interlaced dvd player, the dvd is converted from digital to an analog interlaced signal which then is sent to the 3:2 pulldown unit in the tv which then reconverts it back to a digital signal with some loss of detail and then performs the 3:2 pulldown from which it outputs to the tv. Basically, if you let the tv do the 3:2 pulldown, the tv works with a more degraded image to process after the data comes through d/a conversion.
    A progressive dvdplayer will linedouble via 3:2 pulldown the dvd while its in its original digital state and the output a analog progressive image to your tv once. Hope this helps assuming I make sense.
    Fernando Chen
  3. JohnHN
    JohnHN Stunt Coordinator
    Dec 20, 2000
    91
    The internal doubler on many of the latest HD ready sets perform almost as well on DVD as a progressive DVD player. But the best progressive DVD still offer the best deinterlacing. Don't expect a revolution: if the set is properly calibrated (you may have to recalibrate for progressive as opposed to interlaced) the only improvement will be an increase in resolution (possibly) and a reduction in artifacts. On the latter, the difference will be only occasional. Much of the time there may be no difference at all. But on certain types of material -- closely spaced lines often cause problems -- the internal deinterlacers on TVs can fail dramatically.
    So I wouldn't feel compelled to rush out and get a progressive DVD player. But if you were going to get a new DVD player anyway, then yes you should get progressive.
  4. Fernando Chen
    Jun 30, 1997
    9
    I agree. Its not a requirement that you get a progressive scan dvd player for your hdtv if you already have a player, but if your gonna get a dvd player in the future anyway you may seriously want to consider a progressive scan player. There is a difference with a progressive scan player and it will have an advantage from skipping an additional d/a conversion step, but its not going to be day and night and will vary with content especially with the newer HDTVs.
    Fernando Chen
