3:2 pull down remote for Toshiba 65 H 80
Discussion in 'Archived Threads 2001-2004' started by Fabrice, Mar 20, 2002.
  1. Fabrice
    Fabrice Auditioning
    Dec 19, 1998
    3
    Has anyone had any luck getting the special remote from Toshiba that fixes the 3:2 pull down issue. I have been waiting months and was curious if anyone has had any luck getting one from Toshiba. Thanks...
  2. Corey Hancock
    Corey Hancock Stunt Coordinator
    Oct 30, 1998
    131
    I've got the 40H80 television and I was told it would be about 3 weeks before I got the remote...that was back in November. Anyone else?
    Corey
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Suggest you go out and buy the Cinema 7 remote and use that to activate the 3:2 yourself.
    Takes about 5 minutes ... since it takes so looooong to scroll to the necesssary parameter to change it ...
    Regards
  4. Dave Miller
    Dave Miller Supporting Actor
    May 9, 1999
    854
    5
    110
    Called Toshiba last July and am still waiting.
    Peace,
    DM
  5. Richard Goode
    Apr 11, 1999
    47
    I'am new to the game of calibrating rptv's. I also have a 65h80 I not sure what your talking with 3:2 pull down on the tv. I thought 3:2 was for dvd players. Any help on this would be appreciated.
  6. Corey Hancock
    Oct 30, 1998
    131
    Michael,
    Do you know if you can still buy these in the store? And if so, are these the different model numbers: URC7800, URC7200, URC7801, or URC7802?
    Corey
