3:2 and Progressive question
Discussion in 'Archived Threads 2001-2004' started by Brian Schucher, Jul 18, 2001.
  1. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
    I currently own a Toshiba 65H80 and have activated the 3:2 pulldown feature. I dont have a progressive player at the moment. I have noticed a huge difference after enabling the 3:2 What advantage is there to buying a progressive player? Is it going to be "MUCH" better then using the internal doubler of the TV with 3:2? Thanx
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    Progressive scan will always give you a superior picture to a hd ready sets internal line doubler evan if the internal line doubler does a 3.2 pull down..
    With progressive scan the 3.2 pulldown is accomplished in the digital domain using the frame flags encoded in the dvd's mpeg bitstream..
    Advantages of progressive conversion
    Line doublers are used in other high-end home entertainment systems to provide progressive scanning. These may be stand-alone devices or incorporated into a digital TV. Impressive as they may be, DVD in-player progressive conversion has three big advantages over line doublers:
    1) High precision and stability
    A DVD-Video disc mastered from a film holds all the data necessary to produce an accurate progressive image, whereas an external line doubler must take hints from the video source to determine the source material and frame allocation.
    2) All-digital conversion minimizes signal degradation
    Since the signal from the DVD-Video disc is digital, progressive conversion can be performed digitally inside the player. Signal quality is protected until it leaves the player's analog output. In contrast, a stand-alone or in-TV doubler first receives information from the analog output of the source device then converts this analog signal back to digital for processing. Finally, it must translate the signal back to analog before outputting it. All this back-and-forth translation is much more likely to degrade the signal.
    3) Processing is optimized to DVD-Video's high image quality
    Line doublers built into digital TV sets are designed to work with a variety of video sources, so their settings are not necessarily ideal for DVD-Video. Progressive conversion is optimized for the high resolution and low noise of the DVD-Video format. This enables the unit to preserve DVD-Video picture quality for display on all screen sizes, from direct-view CRT to projectors.
  3. Brian Schucher
    Nov 22, 2000
    700
    Thank you for your informative reply..
