2x3's for walls?
Discussion in 'Archived Threads 2001-2004' started by James Bergeron, Mar 14, 2002.
  1. James Bergeron
    James Bergeron Supporting Actor
    Oct 9, 2001
    831
    My new home has half the walls in the basement as 2x3's with insulation. Basically i'm sure the walls are built like that so that they hold the insulation that's the only reason. Is there a reason for me to tear those down and use 2x4's instead?
    Is there a negative to leaving the 2x3 walls up and finish off the basement with matching 2x3? Or even just finish off with 2x4 anyway and keep the wall that are already done up?
  2. Mark McGill
    Mark McGill Stunt Coordinator
    Feb 20, 2002
    83
    Having built homes in western Canada I have not seen 2x3's used. Nevertheless the finish is up to you. I had a similair situation with our daylight basement. I finished the walls up in some areas and in others I put a MDF cap with trim for the transition. This allows you to use it as a book shelf or whatever. This especially should be done if there are windows on that wall. To even the walls out with the lower 2x3's when there is a window above creates sort of a tunnel effect for the window. I that look is okay then go for it. Remember you are the one that has to look at it. If you like it who cares?
  3. James Bergeron
    Oct 9, 2001
    831
    Well it's just the outside facing walls in the basement. The rest is 2x4's. But I was wondering if it would be structurally not as good with 2x3's, it will simply make the wall 1" thinner in my mind :)
  4. Mark McGill
    Feb 20, 2002
    83
    Shouldn't be a problem. Your foundation is the structure. The 2x3's are just there for insulation and attachement of gyproc. They also provide a small vapour space between the cement and insulation.
  5. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    actually, our house, all the interior walls (including the load-bearing center wall,) are made with 2x3 studs on 16" centers.
    It's thought of as a little odd, but I think in our area, it still meets local building code.
    Personally, I sort of like the idea of a 2x4 header and footer, with staggerd off-center 2x3 studs to provide mechanical seperation between the wall-sides.
    Leo
