$2999 plasma TVs from Gateway?
Discussion in 'Archived Threads 2001-2004' started by Jesse Skeen, Nov 22, 2002.
  1. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,322
    226
    Just saw something on http://www.audiorevolution.com about Gateway (the computer company) announcing a 42-inch plasma TV with a list price of $2999. Anyone else heard about this? If the price gets a little closer to $2500, which is what I paid for my current 4x3 TV, I might go for it!
  2. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    http://www.gateway.com/home/prod/hm_...oddetail.shtml
    Key Features
    Diagonal 42-inch Screen Size
    16:9 Wide Aspect Ratio
    852 x 480 native pixel with progressive scan
    600:1 Contrast Ratio
    570 cd/m2 Brightness
    Integrated Tuner and Speakers
    HDTV Signal Compatible
    160 Degree viewing angle
    Connector Types
    RCA jacks for audio, video, Y/Cb/Cr and Y/Pb/Pr
    6 pin DIN S-Terminal for S Video
    9 pin D-SUB for RS232
    15 pin D-SUB for RGB
    24 pin DVI
    Audio/Video Inputs/Outputs
    1 Composite Video
    1 S Video
    2 Component Video
    1 DVI video input
    1 RGB input
    6 Audio In ( L/R )
    1 Audio Output ( L/R )
    1 Subwoofer output
    • Advanced digital image processing: Get bright, flicker-free pictures with a processor that converts all interlaced signals into more advanced progressive scan. A built-in Digital Visual Interface eliminates the need for analog-to-digital conversion
    • 3:2 pull-down for film scan conversion: Automatically detect and convert film content for better display with minimal motion artifacts
    • Picture-in-picture (PIP): Watch two programs simultaneously using picture-in-picture with four selectable window position settings
    • Picture-on-picture (POP): Watch two programs at the same time
    • Digital zoom modes: Get rid of black bars
    • 3D Comb Filter: For more accurate color processing on S Video and Composite inputs
    • Dual HD component video inputs: Two high-definition component video inputs with auto-detection capabilities automatically synchronize the display to match the incoming signal source
    • Built-in amplifier and speakers: Internal 10-watt (5 x 2 watts) audio and built-in speakers
    • Bass extension circuitry: Option to add a separate subwoofer to enhance bass performance
    • Selectable fixed or variable audio outputs: Use software to select
    • BBE® sound maximizer: Built-in processor optimizes sound quality
    • SRS® sound processing: A built-in sound processor simulates surround-sound effects using only two speakers
    • HDTV signal compatible: Capable of accepting 1080I and 720p HDTV signals using an external HDTV decoder with RGB or component video outputs
    • 1280 X 1024 SXGA support: Built-in digital scaling engine accepts various computer and HDTV signals, then digitally maps the signals to fit within 852 x 480 pixels. Compatible signals include computer display resolutions up to 1280 X 1024 and HDTV signals including 720p and 1080i.
    Dimensions
    Without Stand
    With Stand
    Width
    1040 mm/3.4 ft.
    1040 mm/3.4 ft.
    Height
    648 mm/2.1 ft.
    690 mm/2.3 ft.
    Depth
    95 mm/0.3 ft./3.7 in.
    287.5 mm/0.9 ft./11.3 in.
    Weight
    Net weight 68.8 lbs/31.2 kgs (without stand) 77.2 lbs/35 kgs (with stand)
    Operating
    Temperature 32-104° F (0-40°C)
    Relative humidity 20-80%
    Pressure 800-1114hpa
    Non-Operating
    Temperature (-20 - 60° C)
    Relative humidity 20-90%
    Pressure 700-1114hpa
    Vibration X/Y/Z, 0.5G/10-55Hz (sweep), 10 minutes
    Acoustics
    (ANSI A-weighted 1 meter) 40 dBA spl Max
    Sound
    Residual hum (at volume max) 500 µW Max
    Practical max. Audio output (at 10% THD max) 1.0 vp-p 1 KHz input 5W + 5W Max. / 12 ohm
    Sound distortion (at 250 mw 1KHz) 1% max
    Audio output (input at 1.4 V p-p) >1.0V p-p
    Reliability Requirement
    The MTBF is 20,000 hours under operation at 25+/- 5° C (Half luminosity, motion picture)
    Emissions Requirement
    Your Plasma TV meets the EMI limits in all screen modes as qualified by FCC class B part 15.
    Power Source
    Input voltage 100 - 240 Vac, 50/60 Hz
    Input current 3.3. A
    Inrush current 60 A p-p/20 ms Max
    Power consumption 380 +/- 10% Watts (at 110 Vac/color bar pattern)
    Stand-by and Power Save 5 Watts Max (at 110 Vac)
    Video/ S-Video Signal
    Type Analog
    Polarity Positive
    Amplitude Video 1 Vp-p, (priority S-video) Y=1Vp-p C=0.286Vp-p
    Frequency H: 5.734 KHz V: 60 Hz(NTSC)
    Frequency H: 15.734 KHz V: 60 Hz (NTSC)
    H: 15.625 KHz V: 50 Hz (PAL)
    Input impedance 75 Ohms
    Y/Cb/Cr or Y/Pb/Pr Signal (Component 1 and 2)
    Type Analog
    Polarity Positive
    Amplitude AV: 1 Vp-p (with sync)
    S-Video: Y: 1 Vp-p, C: 0.286 Vp-p
    Frequency
    Y/CB/CR H: 15.734 KHz V: 60 Hz (NTSC)
    Y/PB/PR: HDTV H: 15.625 KHz V: 50 Hz (PAL)
    H: 31 KHz V: 60 Hz (480P)
    H: 45 KHz V: 60 Hz (720P)
    H: 33 KHz V: 60 Hz (1080I)
    RGB Signal
    Type TTL
    Polarity Positive or Negative
    Amplitude RGB: 0.7 Vp-p
    Frequency H: support to 31 K-91 Khz
    V: support to 50-85 Hz
    DVI Signal
    Type Digital
    Frequency H: support to 31 K-63 KHz
    $2999US
    Kevin
  3. Jesse Skeen
    Apr 24, 1999
    4,322
    226
    Hmm, maybe I should boycott it just because of that "get rid of black bars" feature [​IMG] though it might also let me crop TV so I can get rid of the onscreen logos!
    Why do they even bother putting in a built-in sound system when most people aren't going to be using it?
  4. Kyle
    Kyle Stunt Coordinator
    Jan 25, 1999
    134
    Trust me, the built in sound system sux! [​IMG] But it does have a built in tv tuner which most models in that price range don't have. You will want an external audio reciever.
  5. RANDY FISHER
    RANDY FISHER Second Unit
    Sep 1, 1998
    285
    "852 x 480 native pixel with progressive scan
    600:1 Contrast Ratio"
    The resolution and contrast ratio suck. I would NOT buy that thing site unseen. Try to demo it at a Gateway store first to make sure the image is acceptable with a video signal. Most plasma's I have tried out (except for the >$15,000 ones) suck. They look cool off though!
    Randy
