Kevin_Kr
- May 9, 2001
Hello all, just framing off the room soon and cannot quite make up my mine, first was going to do the long way thren thought maybe the short way, benefits of the short way would be I could put a bar in. Thought of putting screen on spots where s is, the #1 represents window. Really could only do the bar if I put the screen on the 16 ft half wall. Planning on 7.1 which would work best long way, ebox is where there are two gaudy junction boxes sticking out. So what do you think?
26ft
------------------------------------ebox-
1 1 l
x
Bx
s ax16ft
rx
?x
16ft s
------------------------ open here but can be framed shut
26ft
1 1 l
x
Bx
s ax16ft
rx
?x
16ft s
