250W PE amp mod
Discussion in 'Home Theater Projects' started by al lout, Dec 31, 2004.
  1. al lout
    al lout Stunt Coordinator
    May 6, 2004
    164
    I'm planning to modify the 250W PE amp mod, adding 2db to 20-24hz region. 1 question, I bought the 2 resistors from radio shack, 47k ohms and 220k ohms. I didn't know that the 220k ohms from RS is 1/2watt. According to PE instruction, it said 1/4watt. Is it matter if I use 220k ohms 1/2watt resistor? Thanks in advanced. I have everything here and ready to go. Just want to confirm this be4 I take the amp apart. Thanks.
    Al,
    Edit: BTW, it's the 250W PE amp part# 300-794.
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    The 1/2W resistor should handle more power than the 1/4W resistor, so you should be okay with using the 1/2W resistor.
  3. al lout
    May 6, 2004
    164
    update: I did the mod on Sunday. Recalibrated everything. I got about a 4db gain from 20hz-24hz (100db to 102db) compared to before (96db to 98db). The mod is fairly simple, just that for the first timer, I have to be extra carefull when I took out the amp. I've soldered the resistors in the back using 47k ohms/ 220k ohms at R26/R27. According to the Mod instruction from PE, those two resistors are supposed to give me a 2db gain in 20hz-24hz region. Somehow I got 4db gain, maybe because I move the sub a couple inches and I also change the wiring from 16ga speaker wire to 12ga speaker wire. So far so good, I need to re-measure my FR to see if there's any big chances. I'm going to watch I Robot now to see how it sounds. Thanks HTF, I did learn alot from you guys.
    Al,
