24X CDR'S Skipping in my RP-91
Discussion in 'Archived Threads 2001-2004' started by Laurence_C, Mar 23, 2002.
  1. Laurence_C
    Laurence_C Stunt Coordinator
    Sep 30, 2001
    174
    110
    North Florida Panhandle
    Laurence
    Anyone having this problem after burning on 24x CDR's. They skip,stop and have a problem playing on my Panasonic DVD-RP91. No problems with any 16x or lower CDR's. The firmware is the 236 version and I'm burning with Roxio 5.02d version. Is it possibly the brand of CDR(Verbatim DataLifePlus)??? These disc play in my car stereo, so I'm totally confused.
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Reading and writing CD-R/CD-RWs can be a crap shoot.
    Could be the discs themselves. Could be the writing speed (try lower). Could be the writing software. Could be the subsequent reader.
    Usually, it's the *interaction* of some or all of the above.
    If they work in your car player, then I'd try some different discs. But I'd try writing at a lower speed 1st.
    I've had good luck with TDK and Fuji.
