24" 16:9 Computer Monitor FS and Viewsonic 22"
Discussion in 'Archived Threads 2001-2004' started by Lawrence F, Jan 21, 2003.
  1. Lawrence F
    Lawrence F Stunt Coordinator
    Feb 8, 2000
    99
    Compaq P1610 which is a rebadged Sony GDM-W900.
    The P1610 has a 22.5-inch viewable image size but uses a 16:10 aspect ratio rather than the more square design of other monitors. HDTV ready as well. Superb CAD monitor. Unsure of value but thinking $825 plus shipping. Has had very little use.
    Reinforcing the old axiom that bigger is better, the Sony GDM-W900 represents the best in desktop-monitor technology. Its 16:10 aspect ratio and magnificent color fidelity usher in a new class of high-end displays. The 16:9 aspect ratio of most vendors' so-called two-page displays (measuring 19, 20, and 21 inches diagonally) rarely allows full-size viewing of those two pages. The GDM-W900, on the other hand, offers true two-page display area–an unbeatable benefit for those involved in prepress or high-end graphics, or who simply require the space of two monitors side by side. Sony also bundles LightSource's ColorTron Color System for calibration and color matching, creating a total package designed with high-end color in mind. As you might expect, the GDM-W900 isn't cheap. At an estimated price of $4999, it's well outside the impulse zone for most users.
    The GDM-W900's primary benefit is space–and lots of it. The monitor measures 24 inches diagonally, with a viewable image size of 22 inches, and supports resolutions from 640 by 480 up to 1920 by 1200. The GDM-W900's wider aspect ratio enables a true two-page display– full-size viewing of two 8.5-by-11-inch documents, with space left over for your application interface. Best of all, the GDM-W900 extends your desktop without requiring an extension to your desk: it's just slightly wider and deeper than a standard 21-inch display.
    To evaluate the GDM-W900, I viewed standard Macworld Lab test images. The GDM-W900's color fidelity, brightness, and contrast were stunning, and its crisp images simulated the appearance of a transparency on a light box. Sony employs a blue filter, which it claims is responsible for the increase in color fidelity and contrast. The display looked bright and crisp without appearing washed-out. Text appeared crisp and graphics maintained outstanding color and contrast on the two-page QuarkXPress test image, and I was delighted at the ability to display the spread full-size.
    Viewsonic PF815
    MINT condition with warranty left. $500
    The PF815 is a 22" monitor with a full 20" viewing area based on an extremely flat aperture-grille CRT with a dot pitch of 0.25mm in the center and 0.27mm at the corners.
    The ViewSonic PF815 has a vertical scanning frequency range of 30–117KHz and a horizontal range of 50–180Hz. Combined with the 300MHz dot clock, these ranges provide display resolutions of up to 1920X1440 at 75Hz. Both BNC and mini D-sub connectors are available, but there is no USB support (coming in Q2). The PF815 is covered by a standard three-year warranty (48-hour replacement coverage is optional). A CD-ROM of screen savers and software control programs ships with the monitor. Five buttons on the lower front bezel of the monitor include a power switch, up, down, 1, and 2. The latter two but-tons serve to access the multilevel on-screen menu system, which includes a full complement of monitor adjustments along with several extras. Among these extras are corner purity, zoom, and a quadrant geometry adjustment feature called hooking.
    The ViewSonic PF815 generates a very pleasing display and turned in perfect scores during our benchmark tests. A miniscule amount of misconvergence appeared on one corner of the display, but not enough to notice without magnification. Color purity was about as perfect as it can get. This is a very impressive monitor at a very good price. Even a year ago, who would have thought you could get this monitor for less than $1,000? You'll find no complaints here. Highly Recommended.
  2. Lawrence F
    Feb 8, 2000
    99
    [​IMG]
  3. Anthony.Lin
    Anthony.Lin Stunt Coordinator
    Sep 27, 2002
    80
    Very nice monitors - I would seriously consider the Viewsonic however I just got a 21" Trinitron. You should consider posting this on other forums - maybe Anandtech's FS/FT section or the like - probably get more responses there.
  4. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    Also I must say those are some seriously nice monitors. I own a Sony 21" and the only reason I will sell this is when I get that Dell 20" Flat Panel I have been looking at so that I can get some desktop space back. The Sony monitor would especially go fast if you can find somone in design.
    KyleS
  5. Adam Krogul
    Adam Krogul Stunt Coordinator
    Feb 25, 2002
    66
    i must say i own the sony gdm-w900 monitor that you say your compaq is, and if it is a rebadge then i can only give high remarks for this fine peice of equipment. you have never seen a "real" computer monitor until you see a 2304x1440 @80 Hz resolution. the sony monitor retails at 2k but luckly last year dell was having a closeout and i got 20% off. one thing to keep in mind about this beast is that it weights 93 pounds...
