200watt vs 125 watt amp
Discussion in 'AV Receivers' started by ScottCarr, Sep 30, 2003.
  1. ScottCarr
    ScottCarr Second Unit
    Jan 28, 2003
    459
    Hi,
    I am in the process of deciding on an exteral amp for my pioneer 49txi. what would I gain if I went with a 200watt amp over a 125 watt amp driving Klipsch RF7s?
    The short list is
    Parasound A51
    Bryston 9B THX
    B&K 200.7
    but 125 what amps are far less expensive.
    thank you for sharing your knwledge and opinions
    Scott
    similar posting over in the klipsch forum.
  2. AaronBatiuk
    AaronBatiuk Second Unit
    Aug 23, 2002
    333
    In terms of difference in loudness, you will gain: 10*log(200/125) = 2.0 dB. Is the extra cost worth 2 dB?
    Klipsch speakers are generally very efficient, so you do not need gobs of power to achieve high output levels with them.
  3. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    Aaron is absolutely right. With the Klipsch's I suggest you stick with 125W/ch and save the money.
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I'd have to agree 200 watts into a Klipshe is over kill to the extreme. I'd also add the Rotel RMB1075 to your list of amps to demo.
