JJR512
- Dec 11, 1999
- Justin J. Rebbert
I just got the 2001: A Space Odyssey Limited Edition Box Set. This is the silver box that includes a 70mm limited edition film frame senitype. I don't know what the technical definition of "senitype" is, but based on the context I assumed it meant it was a film cell. Is that correct? On the back of the card with the film cell and the blowup picture of the scene in the cell, it says this:
quote: ...The film footage is an actual 70 millimeter film frame reproduced from the original motion picture film...[/quote]
What, exactly, does that really mean? Is it a copy of a film frame from the original master film, or is it a piece of film cut out from one of the film sets sent out to theaters, or what.
The thing about it was I figured that the picture you actually got inside the box would most likely be different from the sample shown on the description paper on the back of the box. Yet it is exactly the same scene, a shot of the Earth on the left, a space station in the center, and the shuttle approaching the station from the lower right corner.
Also, inside the box there was a little brochure for other similar collector sets, including the movies Clockwork Orange and Full Metal Jacket in the same style (silver box, senitype, etc.), and another version in a black box called the Signature Series, which features a hand-signed senitype or screenplay. This series includes movies Perfect Storm, Matrix, Exorcist, Bullitt, and Blade Runner. Has anybody got any of these, and what do you think of them?
Finally, inside the shrinkwrap for this 2001 set, on the back side of the box, is a loose paper that explains what exactly it is you are getting. If any of you have gotten these types of sets, what have you done with these papers? They don't fit inside the box. I assume I'm supposed to throw it away, but I never throw anything away.
-Justin "JJR512" Rebbert
Join the JJR512.com Genome@home Team and help cure what ails you. (Click here for more info.)
Contact me: [email protected] | ICQ: 52675695 | Private Message
[Edited last by JustinR on October 23, 2001 at 08:57 PM]
