$2000 to spend - what to get
Discussion in 'Displays' started by Father John A, Aug 24, 2003.
  1. Father John A
    Father John A Stunt Coordinator
    Jul 22, 2002
    146
    A poll: you have $2000. You want widescreen. You are not concerned about HDTV tuner. You do not want FP. Emphasis DVDs.
    What to get?
  2. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Mitsubishi 50" Widescreen HDTV. [​IMG]
  3. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    55" Mitsubishi from sears on clearance $1899, sometimes $1799 at HH Gregg...
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Father John, you're still in decision mode! I believe you've stated a preference for direct-view sets. And with your budget, a Sony KV-36HS510 might do the trick just fine. It's a 4:3 model with a genuine, user-accessible 16:9 mode that will show you DVDs in all their 480p glory. And a few months down the line, when the high-def bug temptation proves too hard to resist, your set will show you gorgeous 1080i images after you purchase the appropriate tuner. Good luck! JB
