$2000 for a large room...
Discussion in 'Speakers & Subwoofers' started by dakine, Apr 13, 2005.
  1. dakine
    dakine Auditioning
    Mar 31, 2005
    7
    I orginally thought I had about 3K to spend on speakes and receiver...but I may be going the 50" plasma route. Can anyone suggest a set up in the area of 2k? The room is 13x21. And are the paradigm HTIB's any good?
  2. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    Are we talking about 5.1 and a receiver?
  3. Christian M
    Christian M Agent
    Feb 2, 2005
    31
    You could probably pick up a very nice ascend acoustics speaker arrangement, a HSU or SVS sub, and a HK, Pioeer, Onkyo, or Yamaha receiver for ~2k +/- a few bucks. I would bet it's better than any HTIB... Paradigm does make some very nice stuff though.
    Good luck!!
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Well 13x21 isn't that big of a room. I still put that in the medium room size cat.
    You have just a ton of options at that price point.
    What ratio of music to HT is your usage?
  5. MikeDuke
    MikeDuke Stunt Coordinator
    Jul 6, 2004
    248
    http://www.definitivetech.com/
    Just as another option
    You could also check out Definitive Technology, mix and match their pro cinema series and come in under $1000 for front, center and surround and then go for a svs or hsu for speakers.
    promonitor 100-$175 each, pro center-$199 each pro80 for surround 112.50 each=661.50
    or the 200 model is $50 more per pair and the better center is $100 more. I think either setup should leave enough left over for a good receiver.
  6. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    For that price i'd consider a similar setup i'd have if not a little better than myself
    Athena AS-f2 front
    Athena AS-c1 center
    Athena AS-b2 rear/rear surrounds
    SVS Sub
    Pioneer 1014tx
  7. Eddie Horton
    Eddie Horton Stunt Coordinator
    May 23, 2004
    237
    You could get 2 pairs of Ascend Acoustics CBM-170's, a CMT-340C, an HSU VTF2-MkII with the Pio 1014 and be under 2K. Superb for the money.
  8. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
    Excellent recommendation by Mr. Norton.
    dakine, you may be able to break it down like this: $500 receiver, $500 sub, and $1000 for 5-7 speakers. If you need to skimp on something to make room for something else, cut back on the receiver. It makes the least impact on overall sound quality.
  9. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I'd say Pioneer 1014TX, Swans 2.1 mains and surrounds, C3 center, and an SVS PB10 sub. This would leave enough money for any cables you might need and stands for the mains/surrounds. If you want to wall mount the surrounds you could also go with the R3 surrounds. Depending on what you spend for cables and stands you might have enough left to move up to an SVS PC 25-31 PCi.
    Check the Swans out at www.theaudioinsider.com . Ascend and Axiom are also great choices. Plasma Docs has some pretty good deals on Ascend/SVS combos. Depends on the sound and look you're going for. Hope this helps [​IMG]
