well, my thought is that you'd get the best quality with a DVI connection and an amp. Though I imagine a high quality cable could make the run without one.
I run a 25ft VGA cable to my PJ. Got it at PCCables.com and have been very happy with it. I don't have DVI so i can't comment on that. I will say the picture quality from the 25ft VGA cable is outstanding. Plus it will be much less $$$ than a 25ft DVI cable.
I haven't seen any 25ft dvi cables and I assumed it was due to some limitation of the nature of the cable. by amp, do you mean an inline amp to amplify the signal? as in connecting:
htpc >> inline amp >> projector?
I haven't seen any inline amps for dvi, but I'll go searching.
and vga doesn't sound too bad either. I'll use that if dvi doesn't work out.
edit: hmm... I found some dvi splitter/amps but they're $200~300+. I also found a 25ft dvi-d-m cable at pccables.com. if that cable is ok, I think I'll go with that. what do you guys think?
I use a thick 25 foot VGA cable myself (no DVI input on the projector). Interesting thing though. I get better picture quality if I pump a high resolution signal through it (I normally project at 1280x720) instead of a low resolution signal which picks up tons of radio interference from the surrounding area (problems start at 800x600). My home theater appears to be located within an RF focal point -- the sub was also affected.
From what I've read, DVI cables appear to have a lot of trouble handling high resolution signals on long cable runs, a total opposite of what I've experienced. But throw in a signal amplifier if available and you might be okay.
BTW, the VGA cable only cost me $50 Canadian, a lot cheaper than a DVI cable and a signal amp.
