2 way splitter question
Discussion in 'Beginners, General Questions' started by Mark__T, Sep 8, 2004.
  1. Mark__T
    Mark__T Agent
    Feb 9, 2001
    47
    If I have to use a splitter, is there any differences between them. For example is there a difference between Radio Shack Goldseries (15-1234) 75-Ohm Coax & Monster Cable 2 Way 2 GigaHertz RF Splitter (TGHZ-2RF)
    Mark
  2. SimiA
    SimiA Second Unit
    Jul 26, 2004
    297
    Yeah!!!!
    The amount of money they cost!!![​IMG] [​IMG]
    Seriously, I've had Rat Shack gold series products, and I've had 2 break within a month, when trying to reconfigure my system inputs/outputs. Seems like the're not very sturdy.
    Vb
  3. Mark__T
    Mark__T Agent
    Feb 9, 2001
    47
    OK Thanks
    What about the Monter Cable brand splitters?
  4. SimiA
    SimiA Second Unit
    Jul 26, 2004
    297
    I'd use them before the Gold series.
    VB
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    RF splitters do have bandwidth limitations, which in layman's terms would be described as VHF quality, UHF quality, or directly in megahertz. I don't have the frequency ranges at hand although 2 GHz should be adequate for any current application. There may also be uneven frequency response which shows up as poor reception of some channels if the original signal strength is not too high to begin with. Only someone's experience such as a magazine review would reveal this kind of problem.
    You probably should not get a 4 way splitter when you need only 2 or 3 way split, since the signal is still divided 4 ways. You probably should split no more than 2 ways if signal strength is not too high (unless you also get a booster amp).
    Video hints:
