2 simple questions
Discussion in 'Archived Threads 2001-2004' started by Jason Wilcox, Apr 13, 2002.
  1. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    1. Is it ok if one of my rear speakers is a 4 feet farther away from the listening postion than the other speaker if they are calibrated with an spl meter?
    2. Would it help to put some sort of plate under a downward firing sub that is on carpet?
  2. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Jason,
    Most DD receivers have the ability to adjust the delay level of the rear channels. Setting them with an spl will keep them the same level, but you should set the delay for the closer speaker a little longer (4-5nS). It will give the effect of being further away.
    The best way to determine about the sub is to try it. Get a piece of wood or even a large enough stepping stone and place under to try it out.
    Bill
  3. Mark Larson
    Mark Larson Supporting Actor
    Mar 3, 2002
    537
    Is your sub already on spikes?
    I think the plate idea is a good one - try granite or marble for the WAF and because they are quite reflective.
  4. Jason Wilcox
    Feb 21, 2002
    652
    My receiver, yamaha htr-5440, does not allow you to set the delay for each individual speaker. As for the sub, I've now got a piece of slate under it. Haven't had the time to really test it out though. Thanks for the advice!
    edit: Since I'm a junior in high school it's more like a MAF (mom acceptance factor)
  5. Mark Larson
    Mar 3, 2002
    537
