AdamWood
- Aug 1, 2003
Ok, so two of these drivers are on their way and should be here tommarrow. Im am trying to design a box for them with WinISD and have came up with a 1.5cuft box tuned anywhere from 20-30Hz. Which would you say? Both of these drivers are going to be sharing the same airspace and being powered by a 250watt PE amp (getting 180watts beacuse of 8ohms).
Here is the T/S's:
Fs-30.4hz, Vas-0.90cuft,
Qts-0.2109, Qms-11.29, Qes-0.215, Mms-61.2g,
[email protected], Bl-13.19Tm, [email protected],Re-3.2ohms,
No-0.324%, Wattage-120w, Sd-201.1sq/cm, Vd-0.24L,
Rms-1.03kg/s, Cms-0.488mm/N, Xmax-12~16mm
So I guess my question is where should I tuned this box at? BTW, my amp has been modded to have its bass boast at 22Hz instead of the 30Hz...
The drivers:
http://mcm.newark.com/NewarkWebComme...jsp?id=55-2421
Here is the T/S's:
The drivers:
