MarcoBiscotti
- Sep 2, 2003
I'm having a big problem which was just introduced to my setup last night...
I'm running a front DLP projector (Digital Projection iVision HDX) in conjunction with a Key Digital HD Leeza video scaler and Pioneer Elite 59-Avi.
The Pioneer goes into the Leeza at 480p and output at 1280x720 via DVI to the projector.
The scaler inputs are set at DVI/HDCP2 (HD) and SDI (SD) according, and the output format to RGBHV.
What I'm seeing, on the right-hand side of the frame ONLY... is a vertical line approx. 2 inches thick, that almost resembles a series of color bars (color squares) in a rainbow pattern from the top of the my screen to the bottom.
This colorful rainbow border has an inherent flicker to it, that is even more distracting than the problem itself and makes watching any movie that isn't wide enough for it to be hidden in the black mask bordering the screen, impossible to watch and focus on.
I have no idea what could be causing this problem, and would like to hear your suggestions on what could be the issue.
Thanks.
Thanks.
