Mike Kao
- Oct 31, 2000
Right now I'm at college and sadly away from my home theatre system. I've tried to replicate my HT at home in my dorm and have come up with a modest 27" Wega & a set of Boston Acoustics BA4800 multimedia speakers (4 speakers/sub). I set my sound system up so the front speakers are used for my computer and the rears are used for my TV & movie material. I have my DVD player route the sound to the TV and the TV back to the speakers, all via anolog connections.
Now I've noticed THREE problems with this setup:
1)Dialog seems a wee bit muffled compared to environmental noises/sound
2) The low-end (bass) doesn't seem to be passed onto the speaker system very well at all
3) Some DVD's sound as if DD5.1 material is trying to go through my 2 speaker system... otherwise sound is surprising crystal clear.
In concern to the last problem, I used the Matrix as a reference for positional audio. Now in the lobby scene, it seems as if sounds that should be going to a center channel (that is non-existance), is coming out, even though only 2-channel information should be processing. For example, whenever a bullet is shot from a front angle (which normally would come out of the center channel on a 5.1 system), I can barely hear it. It's like certain gun-shots are MUCH louder than others... and the sound gets muffled as it pans from left to right. Now I can hear this 'center' info (barely), but it's at a very low volume. I can't tell if this what it's SUPPOSED to sound like on a two speaker system, but it certainly doesn't sound very natural. Technically I could use the TV as a center channel but it's not like I have a digital decoder or any decoder for that matter.
But anyway, I have my DVD player set to PCM audio out (only choices are PCM, Dolby Digital & DTS; however the manual tells you to choose PCM for analog connections), and most DVD disks have a choice on the menu for Dolby, DD5.1 and DTS, but the Matrix doesn't... perhaps that could be it? Does anyone have any other ideas?
[Edited last by Mike Kao on September 16, 2001 at 04:58 AM]
