Can be new or used. Any opinions are greatly appreciated. Thanks.
Apr 17, 2002 #1 of 7 WilliamJay Stunt Coordinator Joined Nov 16, 2001 Messages 52 Can be new or used. Any opinions are greatly appreciated. Thanks.
Apr 18, 2002 #2 of 7 Greg Br Second Unit Joined Dec 13, 2001 Messages 437 The Sensible Sound just had a good review of the AudioSource Amp3 which is $350 MSRP.
Apr 18, 2002 #3 of 7 J John Morris You have lots of choices here. I can vouch for the Parasound amps and the ATI 1502 both of which can be found for less than $500.
Apr 19, 2002 #4 of 7 Chris Tsutsui Screenwriter Joined Feb 1, 2002 Messages 1,865 Yeah a while ago I saw used Parasound HCA-1000As going for $300. You could also get a pre-owned Rotel 2 channel amp for cheap off ebay.
Apr 19, 2002 #5 of 7 Sihan Goi Second Unit Joined Nov 2, 2001 Messages 442 Odyssey Stratos perhaps, if you can get a used one below $500
Apr 19, 2002 #6 of 7 Joseph_Mikhail Stunt Coordinator Joined Mar 26, 2002 Messages 92 I have heard good things about the HK PA2000. You can get it for 299 from OneCall.com
Apr 19, 2002 #7 of 7 Iian M Auditioning Joined Apr 17, 2002 Messages 5 If you want to spend even less, this place has a couple Marantz MA-500 mono blocks for 200ea.(demos)
