$2.5K to spend for a subwoofer...... which one?
Discussion in 'Archived Threads 2001-2004' started by Geo, Dec 12, 2001.
  1. Geo
    Geo Stunt Coordinator
    Aug 15, 2001
    245
    I'm looking to get the best and most bass that $2,500
    can buy.
    I want bass that will blow me away when I want to be blown away. And bass that is tight and clean, as well as deeper than deep............
    My room is 22 x 18 x 9
    Any suggestions??????????
    geo
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,213
    Just one suggestion. SVS SS w/S1000 amp and eq. Does that about cover it? [​IMG]
  3. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    That's easy. Dual SVS CS Ultra Package, or perhaps the SVS SS package if you want the looks.
  4. Brian Mansure
    Brian Mansure Second Unit
    Mar 15, 2000
    460
    Geo,
    I agree with going the SVS route, but you can send me the $2,500 and just enter the SVS giveaway contest[​IMG]
    I'm positive you'll win. [​IMG]
    Hey, I had to try.
    Brian
  5. JerryW
    JerryW Supporting Actor
    Feb 7, 2001
    640
  6. Geo
    Aug 15, 2001
    245
    Thanks for the suggestions......
    One question, Wouldn't a sub like the Velodyne
    HGS-18 with it's 18" woofer go deeper than even a pair of the SVS CS Ultras?
    geo
  7. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Hi Geo,
    I doubt you'd be sorry with a HGS18,very few people seem to feel the need for more output than the big Velodyne flagship can offer.
    There's currently a big subwoofer comparison being done that includes the new Klipsch rsw15,the HGS18,and a dual CS_U/S1000 package.(among others).
    I don't think we'll see the review for several weeks(or even a month or two)...but I'm very confident the overall review will clearly indicate the $2295 SVS package outguns the HGS18.(handily I believe)
    How large is your room?
    TV
  8. Ed St. Clair
    Ed St. Clair Producer
    May 7, 2001
    3,320
    One word, Vandersteen.
    For that sum, you can buy two subs from "The Best Value in Highend" [Stereophile quote and they talking about everything, not just speakers!]. But don't trust Big Ed, check out the subwoofer special edtion Widescreen Review put out. Trust Dr. Boom. You will want to look into the "video" version for your .1.
    You'd get two three hundred watt discrete of USA amps. Not rated to push a test needle at 40% distortion, do I have too name names? That's six hundred watts and two power supplies.
    Six active slot loaded 6 1/2" driver's. Very fast, very musical and the equal of two 15" drivers. And two passive 12" for extra extention.
  9. Shawn Shultzaberger
    Shawn Shultzaberger Supporting Actor
    Dec 2, 2000
    705
  10. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    Try and listen to the Energy MicroStar MS12.1 - hair raising but not tiresome. Deep and loud but tiny box.
    You could almost buy two of them in that budget range too.
  11. bryan_chow
    bryan_chow Agent
    Oct 3, 2000
    43
  12. Keith_C
    Keith_C Auditioning
    Jul 26, 2001
    3
    Hey!,
    check out earthquake subs...I never heard of them but used
    them in an installation. Man, these units can put out SPL at very low frequencies(18HZ). Check out the following review...
    http://www.earthquakesound.com/supernov.htm[​IMG]
