2.35:1 - 1.78:1 Adjustable FP Screen DIY
Discussion in 'Home Theater Projects' started by PhilBoy, Feb 10, 2004.
  1. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    I want to build a wall-mounted adjustable black border screen to perfectly frame all aspects of widescreen movies.
    I would like to be able to manually adjust the height of the screen's frame from top and bottom without moving the projector or adjusting the width of the screen.
    Any ideas ?
  2. MikeWh
    MikeWh Second Unit
    Mar 3, 2003
    407
    What you are looking for is known as "masking" (aka, screen masking, vertical masking). Do a search here and in the screen area at avsforum on the term. You should find plenty of ideas.
    There's a sticky thread at AVS here:
    http://www.avsforum.com/avs-vb/forum...php?forumid=23
    And here's the first DIY I found a couple years ago:
    http://www.kathiejohnson.com/masking.html
    Although, you might find it difficult to find the DrapeBoss motors, as they are no longer made. Some people use wiper or electric window motors from cars.
    I'm experimenting with a stepper motor design right now, but it's all on paper. No materials/testing as of yet.
  3. Jack Shappa
    Jack Shappa Second Unit
    Jan 24, 2003
    411
    Tons of HTF people (including myself) are doing exactly that. In my case, I has the screen framed on the sides with black velvet, then on the top and bottom I mounted those unfinished wooden curtain rods you can pick up at home depot (like 1 1/2" thick or so). I then stapled an 18" strip of velvet to each rod. I roll it up/down to fit the screen size and it looks awesome.
    You'll also want to put a long flat backing piece behind the end of the velvet to give it a nice clean straight line.
    - Jack
  4. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    My masking was cheep and easy, kind of a pain to do manually but I could motorize and automate it if I wanted to put more money into it. See my site!
    Wes
