tiekwando
- Sep 25, 2012
- Eric Morton
Hi Everyone,
I have a thread over on the beginners forum, but since my question is a little more specific i wanted to see what people would say. Big picture I have about $1000 to spend on a receiver, speaker and subs. I will use it 90% with a tv and 10% music. the viewing area is small, but there is no wall between the living room and the kitchen with the total area being less than 2700 cubic ft. Oh and I don't have room for tower speakers just fyi.
After hearing everyone on the other thread I am thinking of starting with a 2.1 or 3.1 system and getting a receiver from accessories4less for around $200. Which brings me to my questions. First I guess is the sub, after reading reviews I think I have found 4 subs that could work,
1) HSU VF2 MK4 ~ 550 - the most expensive by far, but has the lowest hz and seems to get amazing reviews
2) Lava LSP12 ~ 340 - again seems to get pretty good reviews for its price
3) BIC PL-200 ~ 340 (or VK-12 is there a difference between these 2?) same as Lava, but different
4) BIC America F12 ~ 200 - the cheapest by far, consistently recommended, but also the lowest RMS and highest HZ
Then that leaves me with speakers and a budget of anywhere from 250 to 600 for 2 or 3 speakers (its not a hard cap, but a preferred cap if that make sense)-
On the lower budget end the BIC DV series looked good, so a pair of 62si and a 62clrs or possibly a 5.0 energy take classic system which both would be around $250
Mid budget my friend really likes emotiva, but they are all 4 ohm speakers, i figure if i am only running a 2.1 system most receivers may be able to handle 2 of them (assuming volume is left relatively fine). They are on sale currently so I can get a pair of bookshelf speakers for 350 or two LCRs for 400-550
Upperish budget (so 600 for 2-3 speakers) I have absolutely no idea! Anyways thanks in advance for all of your help you all have been extremely helpful so far!
