Frank DG
- Oct 13, 2002
After browsing this forum for a few months, I've finally made my choices for a first home theater set-up.
Denon AVR-1803 receiver
Sony 5-disc dvd player
JBL NSP1 w/ PB10 subwoofer
I have so many questions, but right now, I'm trying to figure out how to hook it all together.
The tv that I'm using now (not for long though) is a Zenith 27". The only connections on this tv are an antenna/cable connection, a right and left variable audio output and an auxillary composite video imput.
The DVD player has 4 outputs: coax digital, composite, s-video and component.
I figured that I would hook the dvd straight to the tv with the composite connection, which I think is my only option. Then the coax digital out to the receiver.
Do I also have to connect the dvd player to the receiver, if so, should that be a component or s-video connection?
How about the tv. Does it get connected to the receiver or is connecting it to the dvd alone sufficient?
Any input is appreciated. Thanks.
