1st Post: Rotel gear in Sydney
Discussion in 'Archived Threads 2001-2004' started by Kris Keen, Aug 26, 2002.
  1. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    Hi All,
    I've recently sold my Onkyo 676 and have decided to go seperates for my next upgrade.
    I live in a 2bedroom unit which is quite open and large, I have a set of B&W 603 S3, 601 S2 and LCR600. I'm considering the following upgrade
    Rotel RSP-1066 pre/pro
    Rotel 1075 5ch amp
    I've heard the B&W are wonderful mates to the rotel line up, I would consider the 1080 later to run my mains for a 7.1 setup. I've read the bass management issues, most threads are from 2001/2000, can anyone confirm these have been addressed?
    Also, where is the best place to obtain Rotel gear in Sydney? I generally deal with Len Wallis for all my audio gear, is Silver a hard finish to find in Sydney? Anyone know some good prices for the above? I'm looking at grabbing the 1075 first next week with the pre/pro to follow..
    Source at the moment is a Denon DVD-1600. I'm on 60% music, 40% home theatre..
    Suggestions, ideas?
  2. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    no one [​IMG]
  3. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
  4. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    Hi Kris,
    So you're feeling neglected? [​IMG]
    I can't speak to the bass management correction directly though it should be fixed by now or at the least shortly due to be. Can't your local dealers confirm?
    Sounds like a wonderful system. The 1075 doesn't look much bigger than the 1066. Should make for a streamlined setup.
  5. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    Ill speak to my retailer next week, they could confirm. I have a SoundStyle XS310 rack, Im hoping I can fit the 1080,1066 and 1075 in it ALONG with the Denon. But I like having the B&W center on the 2nd shelf, i dont think its going to fit [​IMG]
  6. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    Craig, I'm a member there too, not alot of action! heh
  7. Craig_Kg
    Feb 25, 2002
    768
    Try the HT forum there KrisK. The Audio one is a bit quiet.
  8. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    they are both quite [​IMG]
    Where are you located Criag? what sorta system you running?
  9. Craig_Kg
    Feb 25, 2002
    768
    Melbourne.
    My HT system is basic at the moment but ramping up soon.
    Try posting your query in the HT section - you'll get some responses, I'm sure. Lots of Rotel fans (not so many B&W) on the Plaza.
  10. Zacha R
    Zacha R Stunt Coordinator
    Apr 3, 2001
    64
    I'd be interested to know what you find out about the 1066.
    Can you update the thread if you find somewhere here that sells it?
  11. Kris Keen
    Kris Keen Agent
    Aug 25, 2002
    45
    Zac, Len Wallis, Audio Connection and MANY more..
    heaps around [​IMG]
  12. Zacha R
    Apr 3, 2001
    64
    Thanks.
