192 khz DAC vs. 96 khz DAC?
Discussion in 'Archived Threads 2001-2004' started by BenG, Mar 18, 2002.
  1. BenG
    BenG Agent
    Jan 4, 2001
    27
    I'm considering picking up one of the new Onkyo 600's when they come out next month; however, I have the opportunity to purchase an Integra 6.2 right now for a very reasonable price. The only difference that I can discern (a center surround channel is not important to me at all) is the DAC for the L/R channels, the new Onkyo has 192khz/24-bit whereas the Integra has only 96khz. I like the looks of the Integra, and if this is not a huge difference, I'll probably pick it up.
    I listen to lots of 2-channel music, so if this will make a difference, I will wait for the Onkyo. Also, does anyone know if the Integra will handle a 4-ohm load?
  2. Peter Johnson
    Peter Johnson Stunt Coordinator
    Nov 12, 2000
    136
    Whilst its possbile the 192kHz *might* sound better than the 96kHz, its not because of the fact one is 192, and the other 96kHz.
    CD's are 44.14kHz. Thats it.
    The differences between the two DAC sections are more influenced by the DAC chip implmentation, inc. power supply etc, rather than the chip choice.
  3. RicP
    RicP Screenwriter
    Feb 29, 2000
    1,126
  4. brian a
    brian a Second Unit
    Jan 29, 2000
    448
    Ric,
    A question with my new found knowledge. [​IMG]
    you say a lower the occurance of aliasing, but I thought that if you used a lowpass filter on the incomming signal and followed Nyquest's rate aliasing could be avoided all together. Is that not correct.
    Granted I haven't read the chapter on noise shaping other than a quick skim, but I didn't think aliasing would be a bigger problem on a 96KHz ADC than a 192 ADC unless you were trying to capture signals over 40KHz or so. No?
    Also, what source are you currently using you processor's ADC for? I don't think I'll have anything for the Outlaw to sample.
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Ric-
    And...
    (from another thread)
    I was always under the impression that true upsampling (44.1 to 88.2 kHz, etc.) *could* improve the sound.
    But resampling, say 44.1 kHz to 48 or 96 kHz would have the potential of worsening the sound.
    This is why for years and years, the DAT folks tried to avoid sample rate conversion between the CD std of 44.1 kHz and the original DAT std of 48 kHz. And in fact, *now*, all DAT decks are compatible with either 44.1 or 48.
    No "re-sampling" necessary.
    The new Sherwood pre/pro is said to "upsample" CDs to 96 kHz. But to me, that is potentially a very "not-good" thing unless it is selectable.
  6. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Kevin,
    The upcoming pre/pro is based on the R-963 Receiver. It upsamples to 24 bit/192K, not 24/96K.
    All,
    Another reason that 24/192K DACs (with no upsampling implemented) is that the DACs are changing over to 24/192K DACs for DVD0A compabitility.
    Most (but not all) players take the 16/44.1K signal and leave it alone, no upsampling or resampling is performed.
    THere are exceptions.
  7. Marc_E
    Marc_E Supporting Actor
    Oct 9, 2001
    769
    I agree with John, it is prep for future/new media like DVD-A, SACD, and whatever other stuff the electronics/music industry has cooked up to take our money.
    Marc
  8. RicP
    RicP Screenwriter
    Feb 29, 2000
    1,126
  9. Warren_Sc
    Warren_Sc Second Unit
    Mar 2, 2002
    277
  10. Peter Johnson
    Nov 12, 2000
    136
    RicP,
    I know how it all works..I am an EE [​IMG]
    You dont need a 192kHz DAC to oversample. A 44kHz will do it just fine. You can oversample at 8x etc, whatever you want.
    The 192kHz DAC is capable of processing an incoming 192kHz signal. This too can be oversampled.
    Which is absolutely pointless if you dont have a source which will output a 192kHz signal.
  11. Marty Neudel
    Marty Neudel Stunt Coordinator
    Mar 16, 1999
    223
    >Another reason that 24/192K DACs (with no upsampling implemented) is that the DACs are changing over to 24/192K DACs for DVD0A compabitility.<
    John,
    since no receiver is able to take advantage of a digital signal from a dvd-a/sacd player this is (in most cases) a chance for manufacturers to sell us the newest and the latest, taking our money again, and giving us no usable advantage.
    Someday, the music industry may allow us to feed the digital signal from the latest i/p device into our receivers. They may even do it without adding a noise-producing copy protection scheme. And on that day we will all be able to click our heels together three times and follow Toto home.
    Marty
  12. John Kotches
    Mar 14, 2000
    2,635
    Marty,
    The same DACs are often used in DVD players and receivers. As such, the conversion to DVD-A capable DACs is affecting both players and receivers.
  13. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    Wouldn't the main benefit of 192kHz DACs for a receiver be in the digital processing for bass management and DSP modes? Like Peter Johnson, I can't see what a 192kHz DAC has to do with oversampling. The film analogy doesn't work for me either. If you played a 24fps movie at 48fps but showed each frame twice, you still the image aliasing - upsampling and interpolating is a totally different matter and here a 192kHz DAC (with correspinding ADC) could make a huge difference.
  14. Steve & Karen
    Steve & Karen Stunt Coordinator
    Mar 10, 2002
    78
    Since the thread has wandered into the DVD-A & SACD debate, I just wanted to add 2cents for HDCD... it makes a real difference (I can hear it and I don't have audiophile ears)... even for regular CDs not recorded in HDCD... which means in the here, hear [​IMG] & now it makes a real difference for 95% of what most people got.
    -Steve
  15. chung
    chung Stunt Coordinator
    Feb 23, 2002
    234
  16. Peter Johnson
    Nov 12, 2000
    136
    Yes, but the point is, you dont need a 192kHz DAC to over sample up to 192kHz.
    You can oversample as much as you want with any DAC (within reason.)
    192kHz DAC's are new....yet 8x oversampling (just a common number, many go a lot higher) has been around for MANY years.
    192kHz DAC is just capable of accepting a signal which is sampled at 192kHz...which is probably better (Ive never heard one) than anything we currently have. The problem is...what signals sample at 192kHz?
  17. Craig_Kg
    Feb 25, 2002
    768
  18. chung
    Feb 23, 2002
    234
  19. RyanDinan
    RyanDinan Stunt Coordinator
    Oct 25, 2000
    249
    chung,
    I believe this is what Peter is trying to say:
    "Sampling" is the bits of precision along a waveform; i.e., 16bits. The more bits you have, the more smooth your waveform can be. So "oversampling" would be increasing the amount of bits along the waveform - In 3D lingo, it's kinda like adding more verticies along a spline to smooth it out, and not have it be as faceted.
    The frequency is the highest audible range that can be sampled; i.e. 44.1kHz. Meaning, peaks will hit that frequency range. Oversampling does not mean increasing the frequency range. The frequency can be changed from 44.1 to 48 or 96, but that would really not do anything substantial, as there was nothing above 44.1kHz captured to begin with. Oversampling increases the precision of the original waveform - i.e. - going from 16 bits to 20 or 24bits. But the frequency can stay the same....
    I hope my understanding is correct! :b
    -Ryan Dinan
  20. chung
    Feb 23, 2002
    234
