17" LCD Flat pannel for $399
Discussion in 'Archived Threads 2001-2004' started by Westly T, Oct 28, 2002.
  1. Westly T
    Westly T Second Unit
    Oct 5, 1999
    314
    Costco.com is selling the Mirror M17A 17" flat panel monitor for $429.99 with a $30 rebate [​IMG] .
    [​IMG]
    17" SXGA TFT Color LCD Monitor
    Analog signal input
    Active matrix LCD panel with 1280 x 1024 SXGA resolution
    250 cd/m2 high brightness and 16.7M displayable colors
    Auto-adjustment
    VESA wall mountable
    Excellent 400:1 contrast ratio
    Multilingual user controls with OSD menu adjustment
    56~75 Hz refresh rate
    31.8~80 kHz horizontal scan
    Built-in speakers for multimedia application
    Model: M17A
    Resolution: 1280 x 1024
    Contrast: 400:1
    Brightness: 250 cd/m2
    Viewing Angle: 160/160
    Speakers: Yes
    Digital/Analog: RGB 15 pin D-sub (SVGA cable) (no DVI [​IMG] )
    Acrobat Specifications sheet
    Costco usually charges Tax, $34.61 for CA.
    Costco charges shipping of $16.63 when I checked.
    Total of $481.23, then take away the $30 rebate, add $0.37 for a stamp, $451.60 out the door.
  2. Rodon
    Rodon Second Unit
    Jul 4, 2002
    290
    No DVI [​IMG]
    I bought a Planar 19" Black FP with DVI and 500/1 contrast ratio and built in speakers for $603 shipped twons back - one of Dells great mix-ups. Works great and is an awesome traveling FP.
    For those who are on the edge about moving to FP I highly recommend them.
  3. Westly T
    Oct 5, 1999
    314
    I ended up with the same Planar 19', but missed the deal from Dell. Cost me $660 to get it and a bit of searching. The Costco one still doesn't sound too bad though if you don't want to spend the few extra hundred.
  4. Rolie
    Rolie Auditioning
    Nov 5, 2002
  5. Westly T
    Oct 5, 1999
    314
    Keep in mind that with flat panels, that they don't look very clear unless they are in their native resolution. They end up looking blurry when displaying a lower resolution because they have to blend pixels to display it full screen. For me 1280 * 1024 is about as small as I want to go for everyday use on a 19".
