16 gauge wire
Discussion in 'Home Theater Projects' started by calvin_clements, Mar 29, 2004.
  1. calvin_clements
    Mar 6, 2004
    16
    I just moved into a new home where the surround speaker wire (16 gauge) had already been installed in the wall. The speaker run is about 30 feet for 1 side and 17 feet for the other. I just noticed in a Revel speaker brochure online that they do not recommend using a 16 gauge wire for runs longer than 9 feet. According to their chart, I should use either a 10 or 11 gauge wire. Any truth to this? Will it effect sound to that great a degree (bass/soundstage)? I have a Bryston st amp.
  2. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,449
    337
    9,110
    Cees Alons
    Of course 14 or 12 gauge would be better, and for your fronts I would not have recommended 16 g if you had a choice.
    But, hey, those are the surrounds. No extreme power either (if you set them to 'small'). You won't notice the difference. Just calibrate correctly.
    Cees
  3. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    Calvin,
    This write-up should ease your mind a little:
    http://www.procosound.com/Files2/Speakerwp.pdf
    For a 50-foot run of 16-guage speaker wire, you're only losing .5% of the power from your amplifier, compared with .34% for 14-guage and .23% for 12-guage. These numbers assume an 8-ohm load.
  4. calvin_clements
    Mar 6, 2004
    16
    Thanks for the info. The references proved helpful, even with a 4 ohm impedence only a small % change. I also found a link that mentioned that the number of strands in the wire is more important than actual gauge. The strand count in my wire is 30 which is above average.
  5. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Great article Nathan, thanks.
    I never realized the difference in loss in relation to the load level. Interesting.
