16:9 Setting on Sony DBS Receivers
Discussion in 'Playback Devices' started by Neil White, Dec 2, 2003.
  1. Neil White
    Neil White Supporting Actor
    Jan 8, 1999
    551
    I can't find my manual so hoping you guys can answer this. There is an option on all my Sony DBS receivers for setting the TV aspect ratio. What's it for? If something is letterbox I have to use the screen options on the TV to fill the screen. As far as I know Directv does not transmit any anamorphic material.
    What am I missing here?
    N
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    It is to tell your receiver the aspect ratio of your display—it has nothing to do with what is being telecast, but rather with reproducing the signal that is being telecast.
    So, if your TV is a widescreen display, set it to 16:9 and if it is not, then use the 4:3 setting.
  3. Neil White
    Jan 8, 1999
    551
    Lew, sorry to be dense but what effect does it actually have? I tried changing it on the receiver feeding my widescreen and I can't see any difference.
    N
  4. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,943
    27
    1,610
    At present, it has no effect, since DTV is an entirely 4:3 medium. Even movies that are in their OAR are letterboxed within a 4:3 frame.
    So, I don't think it does anything yet.
    BGL
  5. Neil White
    Jan 8, 1999
    551
    Brian, that was my suspicion. Thanks for confirming.
    N
  6. Lew Crippen
    May 19, 2002
    12,060
  7. Neil White
    Jan 8, 1999
    551
    Lew, I was aware of the digital broadcast thing with the transmitted sidebars. Regardless, it has nothing to do with the setting on the receiver as far as I can see. And this aspect ratio setting is on a 6 yr-old receiver I have which way pre-dates HD.
    Still looks like a redundant setting to me.
    N
  8. Brian L
    Jul 8, 1998
    2,943
    27
    1,610
  9. Lew Crippen
    May 19, 2002
    12,060
  10. Brian L
    Jul 8, 1998
    2,943
    27
    1,610
    On a 6 year old box, it does nothing.
    BGL
  11. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
