16:9 mode on 4:3 TVs
Discussion in 'Archived Threads 2001-2004' started by kevin_asai, Jan 3, 2003.
  1. kevin_asai
    kevin_asai Stunt Coordinator
    Mar 12, 2001
    218
    Please enlighten me :b
    I would like to know why this feature makes 16:9 DVDs looks better than if I used Letterbox mode on my DVD player.
    Thanks [​IMG]
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    The simplest way to explain it.
    Because the DVD player sends 75% of the picture information to the TV when the DVD player does it through letterbox. (That missing 25% ain't never coming back.)
    When the TV does it ... it takes 100% of the picture information from the DVD player and squeezes it down so you still see 100% of the picture information. The spaces between the scan lines on the TV are simply smaller. Think Accordion ... or picket fence.
    Regards
  3. kevin_asai
    Mar 12, 2001
    218
    Thanks for the explanation [​IMG]
  4. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    oh man...... now you guys gotta help me out.lol
    ok. I have a 4:3 TV with optional 16x9 squeeze. My dvd player has settings for 4:3 LB and 16x9 whatever...... it has a couple options...... So which do I watch a movie in (tv setting) and what do I set the DVD player to?
    Hope that makes sense!
  5. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Because your TV does squeeze ... A.F.A. the DVD player is concerned ... you have a 16:9 TV. Tell it so.
    DVD player to 16:9 and just pick squeeze / unsqueeze on TV at leisure depending on the DVD material you watch.
    Regards
  6. kevin_asai
    Mar 12, 2001
    218
    This is my current setup:
    DVD player's picture mode: Wide
    TV Display mode: 16:9
  7. Clint B
    Clint B Second Unit
    Jul 14, 2001
    317
    Kevin, it sounds like you've got it right. Assuming "wide" on the DVD player means the same thing as 16:9, you've got it right--as was pointed out before, leave the DVD player in this setting all the time; even 4:3 DVD's will look fine with this setting.
    Just remember that the 16:9 setting on the TV is the same thing as anamorphic squeeze, so only keep the setting on the TV at 16:9 for anamorphic DVD's (which is probably the majority, if not all, of your DVD collection). If you put the 16:9 setting on a non-anamorphic widescreen DVD or a 4:3 DVD, it will squeeze the picture too much.
  8. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    6,023
    40
    6,610
    The BK
    ManW
  9. kevin_asai
    Mar 12, 2001
    218
